Hello,
my name is Nabila, and i'm new here and english isn't my mother-tongue language, i'm sorry if there's any mistake in the way i explain my problem.
My project is to read temperature and command it from matlab to arduino and then plot the data into graphic. The background is showing at the moment i call the arduino, unfortunately the data isn't.
Here is my arduino code :
int mode=-1;
float tempC;
int tempPin = 0;
{ Serial.begin(9600);
//check serial communication-acknowledgment routine
Serial.println('a');
char a = 'b';
while(a !='a')
{//wait specific character from PC
a=Serial.read();
if (Serial.available()>0) //check is any data has been sent by PC
{ mode=Serial.read(); //read request for data
Serial.println(tempC);
switch(mode) //used to set different modes for various operation
case'T': //T is used to read temperature value
getTempCent();//get the value of temperature
//Serial.println(tempC);
void getTempCent()
tempC = analogRead(tempPin);
tempC = tempC * 0.48828125;
and here is the part that cannot show up on the matlab:
%5.Runs a loop that continually read temperature
mode='T';
while(get(button,'UserData'))
tc=ReadTemp(arduino,s,mode);
tcdata=[tcdata(2:end),tc];
set(s,'Zdata',[tcdata;zeroIndex],'Cdata',[tcdata;tcdata])
drawnow;
end
when the graph (without the data appears from arduino) is come out, there's no error in any line.
If there's any possible answer you know, please kindly tell me . And if you need more information about the coding , i'd like to share it with you.
thank you
