What I want to do is to sample an analog voltage from an Arduino pin (0 to 5 V, read as integer values from 0 to 1024), and transmit these samples to Matlab to be plotted. The code below is for the Arduino, it sets up the serial port and then in the loop it reads the voltage from pin 1, sends it to the serial port using “Serial.println”, pauses and then keeps repeating this. The sample rate is set by the pause length.
int analogPin = 1; // Analog read pin. This is the e.g. photodiode input
int result;
int sample = 100; // Sampling period (ms)
int Baud = 9600; // Serial baud rate
pinMode(analogPin,INPUT);
Serial.begin(Baud); // Setup serial port
delay(1000); // 1 sec delay
result = analogRead(analogPin); // read the analog pin
Serial.println(result);
delay (sample);
The following Matlab code configures and opens the serial port, and reads the serial port 100 times and saves these sample values to “y”. The results are then plotted.
clear all
clc
baud = 9600;
arduino=serial('COM3','BaudRate',baud);
fopen(arduino);
x=linspace(1,100);
y=zeros(1,100);
for i=1:length(x)
y(i) = fscanf(arduino,'%d');
end
fclose(arduino);
disp('making plot..')
plot(x,y);
When I have a relatively long delay between sampling the pin (say, 100 ms), everything works perfectly. I switch the input to pin 1 between the 3.3 V and 5 V pins on the Arduino, and the correct values are plotted in Matlab. The problem I encounter is when I decrease the sampling rate (to, say 1 ms). I get the following error:
Warning: Unsuccessful read: Matching failure in format..
In an assignment A(I) = B, the number of elements in B and I must be the same.
Error in Testexample (line 12)
I guess I’m having a problem with reading the serial data, either Matlab is reading in more than one value, or there’s no value to read, and the error occurs because the array y(i) will only accept one entry per column? The data looks fine on the Arduino serial monitor, it looks the same there regardless of the sampling rate.
I don’t really know how to troubleshoot this further, so any pointers would be appreciated.
Thanks!
