MATLAB to Arduino issues *solved*
Hi! Not sure if this is the right forum, anyhow.
I'm trying to create an .m-file in MATLAB that can both send transmit and receive data from an Arduino Uno. The Arduino is set to echo any incoming signal.
When I'm using the mttool(built in tool in matlab) I get the correct values, in eg if I send 1 the received data is 1. But the things is when I try to do this with an m-file I get:
Warning: A timeout occurred before the Terminator was reached.
This is the code I'm using:
% Find a serial port object.
obj1 = instrfind('Type', 'serial', 'Port', '/dev/tty.usbmodemfd131', 'Tag', '');
% Create the serial port object if it does not exist
% otherwise use the object that was found.
if isempty(obj1)
    obj1 = serial('/dev/tty.usbmodemfd131','BaudRate', 9600, 'StopBits', 1);
    fclose(obj1);
    obj1 = obj1(1)
end
% Connect to instrument object, obj1.
fopen(obj1);
% Communicating with instrument object, obj1.
data1 = query(obj1, '1');
fclose(obj1);
I'm using an macbook btw..
I voted for 1. Hope that helps.
Thanks Paul, for your input. Excellent choice.
What's the Arduino code look like?
imagiro1:
  while(Serial.available() == 0);
  int value = Serial.read();
  Serial.println(value);
Every time you open and close the serial port, the Arduino resets. It appears that your MatLab code is doing that a lot.
I did mine a bit different and got the same results you did. Try looking at the code I provided from Matlab.
% Communications MatLab <--> Arduino
% Matlab file 1 for use with Arduino file 1
clc;
clear all;
numSec=1;
t=[];
v=[];
s1 = serial('/dev/ttyUSB1');    % define serial port
s1.BaudRate=9600;               % define baud rate
set(s1, 'terminator', 'LF');    % define the terminator for println
fopen(s1);
try                             % use try catch to ensure fclose
                                % signal the arduino to start collection
w=fscanf(s1,'%s');              % must define the input % d or %s, etc.
if (w=='A')
    display(['Collecting data']);
    fprintf(s1,'%s\n','A');     % establishContact just wants
                                % something in the buffer
end
i=0;
t0=tic;
while (toc(t0)<=numSec)
    i=i+1;
    t(i)=toc(t0);
    t(i)=t(i)-t(1);
    v(i)=fscanf(s1,'%d');       % must define the input % d or %s, etc.
end
fclose(s1);
plot(t,v,'*r')                  % a very interesting graph
                                % if you need precise timing
                                % you better get it from the
                                % arduino (see file 2)
catch me
    fclose(s1);                 % always, always want to close s1
end
Link: Interacting with an Arduino Using the Matlab Serial Commands - File Exchange - MATLAB Central
I think we're missing defining the terminator. Hope that helps.
imagiro1:
clc;
clear all;
numSec=1;
t=[];
v=[];
fopen(s1);
if (w=='A')
end
i=0;
t0=tic;
   i=i+1;
   t(i)=toc(t0);
   t(i)=t(i)-t(1);
end
fclose(s1);
catch me
end
Link: http://www.mathworks.com/matlabcentral/fileexchange/26711-interacting-with-an-arduino-using-the-matlab-serial-commands/content/arduino2matlab/serialTest1.m
Thanks! Solved it!
Thanks! Solved it!
Oh, good. Now we know that it can be done. Just not how...
PaulS:
Thanks! Solved it!
Sorry Paul.
Here is how I solved it.
Matlab
clc;
clear all;
s1 = serial('/dev/tty.usbmodemfa141');    % define serial port
fopen(s1);
if (w=='A')
    display(['Connection established']);
end
fprintf(s1,'%s\n','1')
fscanf(s1)%
fclose(s1);
Arduino
  Communications Matlab <--> Arduino
  Arduino file 1 for use with Matlab file 1
  L. Toms
  establishContact() routine by:
  by Tom Igoe and Scott Fitzgerald
  http://www.arduino.cc/en/Tutorial/SerialCallResponse
  other ideas from
  robot grrrl
  http://robotgrrl.com/blog/2010/01/15/arduino-to-matlab-read-in-sensor-data/
   int ledPin=13;
   int i = 0;
   unsigned char input_PIN = 0;
     pinMode(input_PIN,INPUT);
   // start serial port at 9600 bps:
   //digitalWrite(ledPin,HIGH);
   establishContact();  // send a byte to establish contact until receiver responds
   //digitalWrite(ledPin,LOW);
 if(Serial.read() == '1')
 unsigned int val = analogRead(input_PIN);
 Serial.println(val);
 void establishContact() {
     while (Serial.available() <= 0) {
       Serial.println('A');   // send a capital A
       delay(300);
     Serial.flush();
