Using a UNO and a reading a 4 x 4 Matrix keypad. All well. But the moment I plug in a Ethernet Shield ( W5100 ) the KeyPad code does not work and permanently sends the key "C" which corresponds to the Row 4 and Col 1 location. ( Pin 8 ).
As I can see Pin 8 is not used in the Ethernet Shield- could there be a board problem ? ( The Ethernet board itself is working OK for communications ). The keypad code is below
/* @file CustomKeypad.pde
|| @version 1.0
|| @author Alexander Brevig
|| @contact alexanderbrevig@gmail.com
|| @description
|| | Demonstrates changing the keypad size and key values.
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
{'A','1','2','3'},
{'B','4','5','6'},
{'C','7','8','9'},
{'D','E','0','F'}
byte rowPins[ROWS] = {2, 3, 4, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {6, 7, 8, 9}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void setup(){
void loop(){
char customKey = customKeypad.getKey();
if (customKey){
Serial.println(customKey);
What is wrong ?
