Matrix keypad values on serial?
Hi All,
Is it possible to read Matrix keypad values on serial?.
Regards JR
No idea what you mean. What does "on serial" mean?
If you mean thishttp://playground.arduino.cc/Code/Keypad, the answer is a yes.
Grumpy_Mike: No idea what you mean. What does "on serial" mean?
Hi Grumpy_Mike ,
I mean when you press numbers on the keypad that number has to go on to the serial.For example if you press number 5 on the keypad that number has to got to the serial.So that i can use the below function for my program.
if (Serial.available()>0)
Regards JR
siutoejai: Hi,
Hi siutoejai,
Yes this one only.Thank You. Regards JR
No, that is only used when you receive serial data, you want to send serial data. Your original post should have read:-
Is it possible to read Matrix keypad and then send the values through serial?
You need to decide if you want to send the key pad read as an ASCII character or as a data value. Use Serial.write(keyValue) for data value or Serial.print(keyValue) for ASCII
Grumpy_Mike: No, that is only used when you receive serial data, you want to send serial data. Your original post should have read:-
Hi Grumpy_Mike,
Thank You.
Regards JR
