I see no obvious error; however this depends on my fantasy of what you might have wired...
Because you program is unnessarily complicated it is not so easy to debug.. Some hints:
I strongly recommend that you do everything with unsigned int. This will redundantize half of your lines
It is of no use to set data to low in the beginning and at the end oft the shift routine.
you can digitalWrite(pin, anyvalue_if_0_than its_LOW_otherwise_HIGH)
you can program:
insigned int myMatrix [] = {0x00, 0x00, 0x00,...}
All this will reduce thesize of your code so much that you might detect issues at the first glance
One issue is this: It is of no use to send out the data at afurious rate: Each line has to stay for awhile. A delay between the refreshes of the whole pattern is useless. Only the last line will stay visible... Maybe this is part of the problem??
Consequence: The interrupt routine has to output just one line at a time!!!
I fully understand your setup - this has been done a zillion times before.
I just wanted to make clear that you must give the line a chace nto shine
Of course, {....} can only be used in the definition of the matrix, but that is what you are doing in your current program. It will help when change to 16 bit...Much more readable code!!
I changed the for loop with 16 runs. I did two for loop, one to 0 to 7 and the second, 8 to 15.
I didn't find where I must do a small pause and I didn't find the exception
#include <TimerOne.h>
#include <stdio.h>
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
uint16_t myMatrice[16] = {0x0000, 0x0000, 0x0000, 0x0000,
0x0000, 0x0000, 0x4000, 0xC000};
Serial.begin(9600) ;
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
Timer1.initialize(1000);
Timer1.attachInterrupt(screenUpdate);
void screenUpdate()
uint16_t myRow = 0x0001;
for( byte k = 0; k < 16; k++)
digitalWrite(latchPin, LOW);
shiftIt(~myRow);
shiftIt(myMatrice[k]);
digitalWrite(latchPin, HIGH);
myRow = myRow << 1;
void shiftIt(uint16_t dataOut)
// Shift out 8 bits LSB first, on rising edge of clock
boolean pinState;
//clear shift register read for sending data
digitalWrite(dataPin, LOW);
// for each bit in dataOut send out a bit
for (int i=0; i<16; i++)
//set clockPin to LOW prior to sending bit
digitalWrite(clockPin, LOW);
// if the value of DataOut and (logical AND) a bitmask are true, set pinState to 1 (HIGH)
if ( dataOut & (1<<i) )
{pinState = HIGH;}
{pinState = LOW;}
//sets dataPin to HIGH or LOW depending on pinState
digitalWrite(dataPin, pinState);
//send bit out on rising edge of clock
digitalWrite(clockPin, HIGH);
//stop shifting
void setMatrice1(int* myMat)
myMat[15] = 0x0000; //B 1100 0000 0000 0000
myMat[14] = 0x4000; //B 0100 0000 0000 0000
myMat[13] = 0x0000; //B 0000 0000 0000 0000
myMat[12] = 0x0000; //B 0000 0000 0000 0000
myMat[11] = 0x0000; //B 0000 0000 0000 0000
myMat[10] = 0x0000; //B 0000 0000 0000 0000
myMat[9] = 0x0000; //B 0000 0000 0000 0000
myMat[8] = 0x0000; //B 0000 0000 0000 0000
myMat[7] = 0xC000; //B 0000 0000 0000 0000
myMat[6] = 0x0000; //B 0000 0000 0000 0000
myMat[5] = 0x0000; //B 0000 0000 0000 0000
myMat[4] = 0x0000; //B 0000 0000 0000 0000
myMat[3] = 0x0000; //B 0000 0000 0000 0000
myMat[2] = 0x0000; //B 0000 0000 0000 0000
myMat[1] = 0x0000; //B 0000 0000 0000 0000
myMat[0] = 0x0000; //B 0000 0000 0000 0000
Do you really need a delay between lines?
While outputting one row, the latch is low, which means the 595s will output the previously defined row.
Outputting 4 bytes one bit at a time using slow digitalWrite() will take a while, so it seems to me the "delay" is already there.
What happens on the display when the program is run, does anything show?
Maybe not a huge EXTRA delay.. I have not calculated the time needed for the next row-shift...My experience is that 8 bit shift-out is around 120 to 150us, so 16 bit = 170us or so..
In fact there should be not much difference - as LEDs have low latency - whether you refresh (the complete array) @600Hz and light each line for 100us or refresh with 60Hz and light a line for 1ms.
However if the array refresh is to slow one would see hardlyanything, and we are just troubleshooting....
I don't understand the last two messages, I began.
I modified the code a bit, I changed byte k to uint16_t in screenUpdate(). The code works ans displays items that I want. So thank you. If you think I can optimize it, I listen.
In contrast, the lightness is less.
I have a matrix of white LED 10 * 11. I connected to 5V and I just put the resistors on the +, do I put transistors on -? if so, what transistors?
(1) What has this 10x11 matrix to do with it?
It is connected to shift registers? How.
(2) Your 16x16 matrix is dim. This is typical for those multiplexed things - you have to exactly calculate the current pulses, but on the basis of 1/16 there is little chance. You might look in the datasheet of your specific LEDs to find whether and how long you can pulse them with - say - 100mA or so. But note that the increase of brightness will not be proportional to that current.
Multiplexing LEDs is a complex matter - just read about in the 1000+ internet articles having been written about it during the last 20 years....
You need to post a schematic of what you have. I assume you have some other drivers apart from the shift registers because you will not be able to supply (source) enough current from a shift register alone to light a whole row (16 LEDs) at once.
