Matrix unit board
I want to assembly a simple led matrix which will run a text string.
I would like to be able to store (and call) up to 99 different text strings.
A simple 4 x 4 keyboard would be used as command panel.
I've got Arduino Uno 3
and going to purchase this unit board:
http://www.ebay.com/itm/P4-32X8-Green-LED-Dot-Matrix-Unit-Board-/181350983983?pt=LH_DefaultDomain_2&hash=item2a395c692f
and this 4x4 keypad keyboard:
http://www.ebay.com/itm/1Stk-16-Key-Membrane-Switch-Keypad-Keyboard-4-x-4-Matrix-Array-fur-Arduino-AVR-/181501140290?pt=Elektromechanische_Bauelemente&hash=item2a424f9d42
So when I type, for example No 12, text string No 12 would run on the board unit until I type new two digit number.
Is it possible to make it work with these components? (I do have many different power supplies and connection cables)
Do I need more components?
Is there more simple way to do it?
Bump! :frowning:
Look to see if there is a library to drive that LED matrix.
ChilliTronix:
I should probably use some other LED matrix with approximately same size.
I can't find the library for this one.
This one looks promissing:
http://www.ebay.com/itm/RED-32x8-LED-Matrix-Display-3mm-Dot-size-Arduino-LPCXPresso-ARM-AVR-nRF51-/251588405297?pt=LH_DefaultDomain_2&hash=item3a93d66831
Any other suggestions?
Looks OK.
Download the library, install it into the Arduino IDE then write a program with it and check it compiles OK.
ChilliTronix:
Looks OK.
Thanks,
I guess I need to install library for 4x4 key pad too.
Look at the parola library for driving multiple LED matrixes with a MAX7219 for each 8x8 display.
Daisy chain the MAX7219's together. The library supports many configurations.
I seem to remember that there are some keypad libraries about, especially if it is a simple 3X4 or 4X4 one.
Keypad.h from the playground, works very well. Example given is 3x4, easy to adjust to 4x4.
