Help me !!
Why is the value readable? I connected the wrong circuit ?? I try to thermocouple type k with max31855 and still can not read the temperature, help me, thanks for the advice so sorry i bad engilsh:(
No link to the used hardware (I assume you don't use the chip directly but some breakout board), no wiring diagram, no code used. I hope you understand that the offered information is to lean to enable us to help you.
OP's image:
As my signature says, the problem is in the code you didn't post. It may also be in the schematic or wiring diagram you didn't post.
