MAX 6675 - Live Reading Problem
Hello Everyone!
I’m using MAX 6675 module, with max6675 library.
I’ve uploaded the basic example, and it works fine:
// this example is public domain. enjoy!
// www.ladyada.net/learn/sensors/thermocouple
#include "max6675.h"
int thermoDO = 11;
int thermoCS = 12;
int thermoCLK = 13;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
  Serial.println("MAX6675 test");
  // wait for MAX chip to stabilize
  // basic readout test, just print the current temp
   Serial.print("C = ");
   Serial.println(thermocouple.readCelsius());
   Serial.print("F = ");
   Serial.println(thermocouple.readFahrenheit());
By “works fine” I mean the temperature is changing, and showing the changes on the Serial Monitor.
I’ve tried to implement it in my code:
while (PS == 1){
    if (check == 2) {
      Serial.println("Pedal Was Pressed. Now awaiting START command.");
      check++;
    PedalState = digitalRead(Pedal);
    if (PedalState == 0) PS = 0;
    digitalWrite(Pneumatics, HIGH);
    MeasuredTemp = thermocouple.readCelsius();
    SendMesuredTempToDisplay(MeasuredTemp);
    Serial.print("1. Temp is ");
    Serial.println(MeasuredTemp);
    StartState = digitalRead(Start);
    if (StartState == 1) StS = 1;
    delay(1);
    while (StS == 1){
      if (check == 3) {
        Serial.println("Start Button was pressed.");
        check++;
      HeatingProccess();
      CoolingProccess();
      if (check == 11){
        Serial.println("Done with heating and cooling, exiting 'if' command");
        check++;
    if (StartState == 0){
      delay(1);
Heating Proccess (another place that the values of thermocouple is being read):
void HeatingProccess(){
  Serial.println("Heating Started");
  while (MeasuredTemp <= HeatingTemp){
    digitalWrite(Heating, HIGH);
    Serial.print("2. Temp is ");
    if (check == 4) {
      Serial.print("Heating to heat temperature ");
      Serial.print(HeatingTemp);
      Serial.print("\n");
      check++;
    //Serial.println(MeasuredTemp);
  if (check == 5) {
    Serial.print("Heat done. Now maintaining temp for ");
    Serial.print(HeatingTime);
    Serial.print(" msecs.");
    Serial.print("\n");
    check++;
  StartTime = millis();
  EndTime = StartTime + HeatingTime;
  while ((EndTime - StartTime) <= HeatingTime){
    if (check == 6){
      Serial.println("Started Counting time");
      Serial.println("Start Time: ");
      Serial.print(StartTime);
      Serial.print("\n");
      check++;
    temp_check[0] = MeasuredTemp;
    delay(50);
    temp_check[1] = MeasuredTemp;
    if ((temp_check[1]-temp_check[0])>0) index=1;
    else if ((temp_check[1]-temp_check[0])<0) index=-1;
    if (MeasuredTemp <= HeatingTemp+HeatingTemp*Err) {
      Serial.println("if_1");
      Serial.println(Err);
    else if (MeasuredTemp > HeatingTemp-HeatingTemp*Err) {
      digitalWrite(Heating, LOW);
      Serial.println("if_2");
    else if ((index == 1) && (MeasuredTemp > (HeatingTemp-HeatingTemp*Err)) && (MeasuredTemp < (HeatingTemp+HeatingTemp*Err))) {
      Serial.println("if_3");
    else if ((index == -1) && (MeasuredTemp > (HeatingTemp-HeatingTemp*Err)) && (MeasuredTemp < (HeatingTemp+HeatingTemp*Err))) {
      Serial.println("if_4");
    else Serial.println("Failed to determine if temp is rising or falling");
    EndTime = millis();
  if (check == 7){
    Serial.println("Heating Done by time. End time: ");
    Serial.print(EndTime);
    Serial.print("\n");
    check++;
The Problem I’m having is as follows:
The program starts fine, then when I step into the posted “while” loop, the thermocouple reading shows a temperature, however - it does not change when I apply heat to the thermocouple.
When the program steps into the “HeatingProccess” function, the thermocouple reading changes (as if it did read the sensor properly), but again - the value does not update live.
I’m guessing its some kind of logical problem, but can’t seem to figure it out.
Any help would be greatly appreciated :slight_smile:
OK, so I figured it out, if anybody has the same problem in the future:
The MAX6675 module can read values every 170-220 ms, so between 2 readings there should be a delay, of 220 ms.
