MAX 6675 mit OLED SSD1327 128x128
Hallo zusammen,
hab da mal wieder ne Frage.
Ich habe einen MAX6675 Sensor der mit einem 96x96 OLED Display funktioniert.
// Add libraries
  #include "U8glib.h"
  #include <SPI.h>
  #include <Wire.h>
  #include "max6675.h"
// change between Centigrade and Fahrenheit here
// REM out the line not needed
  boolean centigrade = true; //Un REM this for Centigrade and REM out line below
//  boolean centigrade = false; // Un REM this for Fahrenheit and REM out line above
// setup u8g object
  U8GLIB_SSD1327_96X96_2X_GR u8g(U8G_I2C_OPT_NONE); //IIC
  double max = 215; // maximum temperature
  double min = -215; // minimum temperature
  float currentTemp = 0.00;
  String thisTemp = "";
  int maxTemp = 0; // maximum temperature reached
  int minTemp = 0; // minimum temperature reached
  int pad = 0;
// Thermocouple MAX 6675
  int thermoDO = 6;
  int thermoCS = 5;
  int thermoCLK = 4;
  MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
  int vccPin = 3;
  int gndPin = 2;
void draw(void) {
  u8g.setFont(u8g_font_profont15);
  u8g.drawStr(10,10, "Motortemperatur");
  u8g.setFont(u8g_font_profont12);
 // show max temp reached
  u8g.drawStr(10,25, "max");
  if(maxTemp <= int(currentTemp)){ maxTemp = int(currentTemp);}
  thisTemp = String(maxTemp);
  if(centigrade){
    thisTemp = thisTemp + "\260C";
  else{
    thisTemp = thisTemp + "\260F";
  const char* maxTempC = (const char*) thisTemp.c_str();
  u8g.drawStr(30,25, maxTempC);
 // show the min temp reached
  u8g.drawStr(70,25, "min");
  if(minTemp >= int(currentTemp)){ minTemp = int(currentTemp);}
  thisTemp = String(minTemp);
  if(centigrade){
  else{
  const char* minTempC = (const char*) thisTemp.c_str();
  u8g.drawStr(90,25, minTempC);
  u8g.setFont(u8g_font_profont29);
  if(currentTemp > 99){pad = 2;}
  if(currentTemp > 9 && currentTemp < 100){pad = 10;}
  if(currentTemp < 10){pad = 18;}
  thisTemp = String(currentTemp);
  if(centigrade){
  else{
  const char* newDispC = (const char*) thisTemp.c_str();
  u8g.drawStr(pad,62, newDispC);
void setup(void) {
  Wire.begin();
  // use Arduino pins
  pinMode(vccPin, OUTPUT); digitalWrite(vccPin, HIGH);
  pinMode(gndPin, OUTPUT); digitalWrite(gndPin, LOW);
  delay(500); // wait for MAX chip to stabilise
  if(centigrade){
    currentTemp = thermocouple.readCelsius();
    minTemp = int(thermocouple.readCelsius());
    maxTemp = int(thermocouple.readCelsius());
  else{
    currentTemp = thermocouple.readFahrenheit();
    minTemp = int(thermocouple.readFahrenheit());
    maxTemp = int(thermocouple.readFahrenheit());
void loop(void) {
  currentTemp = 0;
  for(int f = 0; f <25; f++){
    if(centigrade){
     currentTemp = thermocouple.readCelsius() + currentTemp;
    else{
      currentTemp = thermocouple.readFahrenheit() + currentTemp;
  currentTemp = currentTemp/25;  // averages out 25 readings
  // picture loop
  u8g.firstPage();
  do {
    draw();
  } while( u8g.nextPage() );
  // rebuild the picture after some delay
  delay(50);
Nun möchte ich diesen mit einem 128x128 Display benutzen. Ich habe den Sketch umgeschrieben, leider
funktiomiert es nicht und das Display bleibt dunkel
// Add libraries
  //#include "U8glib.h"
  #include <SPI.h>
  #include <Wire.h>
  #include <U8g2lib.h>
// setup u8g object
  //U8GLIB_SSD1327_96X96_2X_GR u8g(U8G_I2C_OPT_NONE); //IIC
  U8G2_SSD1327_EA_W128128_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
  //U8G2_SSD1327_EA_W128128_1_SW_I2C u8g2(U8G2_R0, /* clock=*/ 5, /* data=*/ 4, /* reset=*/ U8X8_PIN_NONE);
  int pad = 0;
  int thermoDO = 6;
  int thermoCS = 5;
  int thermoCLK = 4;
  int vccPin = 3;
  int gndPin = 2;
void draw(void) {
  u8g2.setFont(u8g2_font_6x10_tf);
  u8g2.drawStr(10,10, "Motortemperatur");
  u8g2.drawStr(10,25, "max");
  if(centigrade){
  else{
  u8g2.drawStr(30,25, maxTempC);
  u8g2.drawStr(70,25, "min");
  if(centigrade){
  else{
  u8g2.drawStr(90,25, minTempC);
  u8g2.setFont(u8g_font_profont29);
  if(centigrade){
  else{
  u8g2.drawStr(pad,62, newDispC);
void setup(void) {
  Wire.begin();
  // use Arduino pins
  if(centigrade){
  else{
void loop(void) {
  currentTemp = 0;
    if(centigrade){
    else{
  // picture loop
  u8g2.firstPage();
  do {
    draw();
  } while( u8g2.nextPage() );
  delay(50);
wo ist mein Fehler?
Hast du denn das Display mal nur mit einem Beispiel (Test) Sketch probiert, also ohne den ganzen Sensor-Kram ?
Das ist normal immer das Erste was man macht.
Hi HotSystems,
ja, ich habe das Display auch schon mit einem anderen Sketch ausprobiert, da funktioniert es einwandfrei.
Dann vergleiche mal den jetzigen Sketch mit denen, in dem es funktionierte.
Finde heraus, was Du in der Ansteuerung des Displays anders machst und Du hast die Lösung.
Serielle Testausgaben sind auch oft hilfreich.
Gruß Tommy
Was hältst Du von u8g2.begin(); ?
..... heißt u8g2.begin()
Kommt vor
u8g2.setFont(u8g2_font_6x10_tf);?
Nee, hinter Wire.begin();
Hallo,
u8g2.begin(); vermisse ich auch.
Wire.begin(); erledigt u8g2.begin(); eigentlich gleich mit, habe ich bei mir im setup(); nicht mit drin.
Den genauen Displaytyp hast Du ja nicht verraten, bei meinem China-Teil ist der Treiber:
U8G2_SSD1327_EA_W128128_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
Gruß aus Berlin
Michael
amithlon:
Ja, "eigentlich" ist richtig, aber bei mir (IDE 1.8.6 mit aktueller Bibliothek) lese ich error: 'Wire' was not declared in this scope. Da müssen wir mal bei Gelegenheit Oli Kraus fragen.
Hallo,
hier 1.8.7 und U8g2-2.23.18. Benutze die sonst nicht, wollte eben ein solches 128x128 OLED testen.
Hmmm, ohne Eingriffe könnte ich das Demo für den Nano mangels Ram nichtmal wirklich nutzen.
Wire.begin() wird aber in der U8x8lib.cpp von u8x8_byte_arduino_hw_i2c aufgerufen, bei mir wird das auch nicht angemault.
Gruß aus Berlin
Michael
amithlon:
Die seitenweise Seitenaufbereitung spart Speicher, dann paßt es auch in einen UNO und Nano. Das "F" steht für full, also die gesamte Seite wird in den Nano-Speicher gelegt, das paßt nicht.
Oh,
so klappt es.
habe den Sketch nun so geändert:
  #include <SPI.h>
  #include <Wire.h>
// setup u8g object
  int pad = 0;
  int thermoDO = 6;
  int thermoCS = 5;
  int thermoCLK = 4;
  int vccPin = 3;
  int gndPin = 2;
void draw(void) {
  if(centigrade){
  else{
  if(centigrade){
  else{
  if(centigrade){
  else{
void setup(void) {
  Wire.begin();
  u8g2.begin();
  // use Arduino pins
  if(centigrade){
  else{
void loop(void) {
  currentTemp = 0;
    if(centigrade){
    else{
  // picture loop
  u8g2.firstPage();
  do {
    draw();
  delay(50);
Das Display ist auch nen China dingen:
1.5" OLED Module
Driver: SSD1327
Bus: SPI
Dots:128x128
Hallo,
agmue:
Danke für den Hinweis.
Kommt davon, wenn man, wie ich, die Lib sonst nicht nutzt und außerdem meist mit einem ESP8266 testet...
Gruß aus Berlin
Michael
Hallo Zusammen
Entschuldigt, hatte den Thread nicht gelesen. Aber es scheint ja schon alles gelöst zu sein: Sehr gut!
Ansonsten könnt ihr mir auch gerne zu U8g2 Problemen direkt ein Issue im U8g2 projekt (Issues · olikraus/u8g2 · GitHub) stellen. Gerne auch auf Deutsch...
Grüße,
Oliver
