max current draw with relay board, input buttons and rs485
Hello guys,
I am currently developing a system for controlling lights powered by a 12V photovoltaic system.
For this purpose I have some Arduino UNOs connected by RS485 controlling an 8-channel relay board (LINK) and 8 buttons connected by the usual schematics (5v supply with 10KOhm resistor).
Each external component (RS485 chip, relay board, input buttons) will be powered by a separate 5v source, the 5V output of the UNO is not used.
The documentation of the relay board says that it consumes 15-20mA per channel, so I am not sure if the board will be capable of running all 8 channels with input buttons and RS485 communication (and optionally some sensors) simultaneously without going up in smoke. I read that the maximum current draw is 200mA for the whole Arduino board, so this is quite near the limit.
I would be happy and thankful for any suggestions!
That is the limit of the total current of the processor chip sourcing current, not the board.
Any chance of a link that works?
Sorry, here is the correct link. Also corrected it in the original post.
There some limits on groups of pins too:
http://www.gammon.com.au/uno
You might want to invest in some MOSFETs to reduce the strain on the processor pins.
Thanks a lot for that interesting link.
According to a discussion HERE, it seems that the 15-20mA rating is wrong. Instead, the input circuit of the relay board only draws 1.5mA from the I/O-pin, but the relay coil behind the input circuit uses about 60mA when it is in operation. That seems to make sense, but I guess I have to check that for myself :slight_smile: The board should arrive here in some days ...
I just put an amp meter inline with the input pin on two diferent relay boards (not the one you specified),
One had 3.8ma draw, the other had 6.2ma draw.
I also would expect their rating is wrong. If you have the relay, and have a meter, give it a test.
If you have not yet ordered it, you may want to bypass that one.
