Max datarate of xBee 1 series??
I'm doing a little project in wich I send temperature info to pc using 2 xBee's an arduino one, and in the code i send this strings for the serial way, "Lectura analogica 109.9 - Temperatura calculada: 100" The problem is when I try to send the info the xbees dont respond, then I just send the number off the temperature, in this case the xbees respond very well. Then I wonder if I 'm passing more data that the module xbee can send, I read in the info guide that te datarate of transfer is 250 kb/s, How I know how many bits I'm sendig to th pc???
Thanks you!!
Count the number of bytes sent in one second and multiply by 8.
Is all the text really necessary? Isn't the position of the numbers enough?
