Can someone give out how it can be implemented below equation.
How to calculate unbalance –
Unbalance is calculated in terms of maximum deviation of current in a phase from the mean of three phases. To calculate the percentage deviation- [1]
Unbalanced_Formula
Where- Im is mean of currents in three phases (i.e. Im= (Ir+Iy+Ib)/3
Ir, Iy, Ib are phase currents.
Besides, an unbalance can also be quantified by comparing the intensity of negative sequence currents in comparison to the positive sequence currents. The permissible limit in terms of percentage of negative phase sequence current over positive sequence current is 1.3% ideally but acceptable upto 2%.[2]
const uint16_t unbalance_limit_precent=10;
uint16_t RYB_arr[3];
uint16_t I_Average, I_unbalance, temp ;
uint_8t CRUnblance_Flag=0;
//put in the 3 phase currents in whatever order you want
RYB_arr[0] = Rph_Current; //the actual readings here into the array. dont really need an extra variable
RYB_arr[1] = Yph_Current;
RYB_arr[2] = Bph_Current;
//sort the array in ascending order
for(uint8_t i=0;i<3;i++)
for(uint8_t j=i+1;j<3;j++)
if( RYB_arr[i] > RYB_arr[j])
tmp = RYB_arr[i];
RYB_arr[i] = RYB_arr[j];
RYB_arr[j] = tmp;
I_Average = (RYB_arr[0]+RYB_arr[1]+RYB_arr[2])/3;
I_unbalance = (RYB_arr[2]-RYB_arr[0])/I_Average; //RYB_arr[2]: Max Phase Current, RYB_arr[0]: Min Phase Current
if((I_unbalance/100)>unbalance_limit_precent) //I_unbalance converted into percent
CRUnblance_Flag=1;
}else
CRUnblance_Flag=0;
AJITnayak:
But I wanted to know in which two phase unbalance has occurred. can someone guide me here
what should be the nominal current in a balanced situation? u can use that to then identify you unbalances phases
Strictly speaking in an unbalance situation (assuming all 3 phase currents can be adjusted), ALL 3 phases are unbalanced and to balance them would mean to make them shift toward the average calculated current.
