How much of a load can be put on the 5v pins of the duemilanove?
this reads like its the same question that you asked here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1248497122/1#1
If your question is how much current can the onboard regulator provide, it depends on the voltage of your external power supply. The regulator is rated at 800ma but it has a very small copper area for a heat sink so it will be much less than that. I would guess that with a 9 volt supply the regulator would be start getting noticeably hot at something like 200 or 250ma.
