Max/msp+Maxuino+TB6600+arduino+nema17 (TB6600 Stepper Motor Driver)
Hello, I'm a novice. Ask you all,
I tried Max/msp+Maxuino+Easydriver+arduino+nema17, and run normal。
Then I want to try to use Tb6600
https://www.dfrobot.com/wiki/index.php/TB6600_Stepper_Motor_Driver_SKU:_DRI0043
I use this connection to test the stepper motor. It rotates normally.
Then I use TB6600 instead of easydriver, the motor is fixed, but the motor can not be rotated by using maxuino.
Does maxuino control Tb6600?
Ask you, thank you.
Try this Simple Stepper Code with both motor drivers. I believe it should work with both.
If it does not work with both motors then you have something wrong that needs to be fixed before trying to use more complex code.
One thing to note is that the Easydriver defaults to microstepping IIRC whereas I thing the TB6600 defaults to single stepping.
Also it may be that the TB6600 requires the enable pin to be held HIGH or LOW to get the motor to work. Not all drivers have it set for working by default.
...R Stepper Motor Basics
Thank you for your answer. I'll try it.
