Max transfer speed possible for the Ethernet 2 Shield, with UDP connections?
Hi, I was wondering if there’s anyway to speed up UDP transfer for sending with the Ethernet 2 Shield using an Arduino Uno. I’m using the Ethernet 2 library.
So far what I’ve tried is commenting out this from "utility/socket.cpp since I know the UDP packet size I have to send:
uint16_t bufferData(SOCKET s, uint16_t offset, const uint8_t* buf, uint16_t len)
  uint16_t ret =0;
  if (len > w5500.getTXFreeSize(s))
    ret = w5500.getTXFreeSize(s); // check size not to exceed MAX size.
    ret = len;
 ret = len;
  w5500.send_data_processing_offset(s, offset, buf, ret);
  return ret;
Which then increased my sending rate from 2.84Mbits/sec to 2.93Mbits/sec.
What I did to track this was test with iPerf 2.0.5 over a 10 second interval, sending 1024byte packets.
As far as I know, the Ethernet 2 shield has a 100mbps speed, so I expected something closer to that.
Any ideas/help would be appreciated. Thanks!
The abbreviations M and m cause the values to be many orders of magnitude different. Proper use of M or m is extremely important.
UDP is used when you don't really care that the data got to the intended recipients - like posting a notice on a bulletin board. Speed is rarely an issue with UDP.
If speed IS an issue, then UDP is likely to NOT be the correct protocol to use.
Finally, there is a big difference in bits/second and bytes/second. The mbps value that you (incorrectly) quote is not clear whether that is bits per second or bytes per second.
valcroft:
The UNO could at very best load the Ethernet card with data at 8Mbit/s, thats the limit of the SPI interface between the UNO and the Ethernet device.
Given some software overhead on the UNO side, 3Mbit/s seems about right.
Hi thanks for the replies!
PaulS:
UDP is used when you don’t really care that the data got to the intended recipients - like posting a notice on a bulletin board. Speed is rarely an issue with UDP.
Sorry about the 100Mbps mistake. It should be 100 megabits per second sorry, and hence 100Mbps. For my use case I really intended for UDP since I was looking at the bandwidth an Arduino is capable of. Turns out that 8Mhz SPi transfer speed is the limit.
But sorry I think what you’re trying to correct me on is wrong, the small “m” matters if for “milli”. It’s the “B” that matters for “B” Bytes or “b” bytes.
srnet:
Thanks for confirming! It does make sense that the SPI transfer is the limit for that case. I’ll do a computation for it to prove it to my peers. It’s just that someone at our lab did a similar project, and had really high performance which was dubious.
For others looking at this post, someone also did this comparison, altho for W5200 but is comparable: DUEZoo/wizperf.txt at master · manitou48/DUEZoo · GitHub
*not sure it tagging is done right with this post. Is my first time I think posting here and I’m replying with my phone
