Max Voltage on Vin Pin Maker Zero
Hi All,
What is the maximum voltage that can be applied to the MKR Zero's Vin Pin?
Seems to be 5.5V but I'm not sure.
Can anyone maybe confirm the Vin in maks of the MKR Zero Vin pin.
Much appreciated.
Looking at the schematic and reading Arduino specs, 5.5V is the max. Personally I think you could push it to maybe 6.5 or 7 but I would not go above 5.5V as there will be no benefit.
NOTE many other Arduino boards allow higher voltages at Vcc or Vraw but these boards have onboard voltage regulators the Mkr Zero does not.
So don't be confused about conflicting claims of higher voltages on your MKR. Much above 5.5 volts and you will end up with a useless board.
