Why MAX30100 oximeter does not measure when I added the code of RF transmitter?
Here is the code
//the Arduino Nano 2 will be used to continuously check if the oxygen
//threshold is exceeded or not knowing that the normal oxygen level is
//more than 88% and whether the bracelet pushbutton is pressed or not
//to send a signal equals 1 to Arduino UNO
#include <RH_ASK.h> // Include RadioHead Amplitude Shift Keying Library
#include <SPI.h> // Include dependant SPI Library and it is not actually used but needed for compilation
// Include Libraries needed for oximeter
#include <Wire.h>
#include “MAX30100_PulseOximeter.h”
#define REPORTING_PERIOD_MS 10
PulseOximeter pox;
uint32_t tsLastReport = 0;
RH_ASK rf_driver;
// Callback (registered below) fired when a pulse is detected
void onBeatDetected()
Serial.println(“Beat!”);
int x=3;
int pushbutton=7;// Bracelet pushbutton is connected to digital pin 3
int RF1_trans=12;// RF transmitter_1 is connected to digital pin 12
//int Sda=4; Clock data pin is connected to digital pin 4
//int Scl=5; Clock input pin is connected to digital pin 5
//int Int=2; Interrupt pin is connected to digital pin 2
int Y[4]={0,0,0}; // Array to use three readings to ensure that the threshold is exceeded
pinMode(pushbutton,INPUT_PULLUP);// Declare pushbutton as input_pullup
pinMode(RF1_trans,OUTPUT);// RF1_trans as output
pinMode(3,OUTPUT);
// Initialize the oximeter and check if it works properly
Serial.print(“Initializing pulse oximeter…”);
if (!pox.begin()) {
Serial.println("FAILED");
for(;;);
Serial.println("SUCCESS");
// Register a callback for the beat detection
pox.setOnBeatDetectedCallback(onBeatDetected);
// Initialize ASK Object
rf_driver.init();
// To reduce error, array Y is used to store three values and then
//compare them with a certain threshold to take an action accordingly
pox.update();
for (int j=0; j<3;j++)
if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
Serial.print(" SpO2:");
Serial.print(pox.getSpO2());
Serial.println("%");
tsLastReport = millis();
Y[j]=(pox.getSpO2());
Serial.println(j);
Serial.println(":");
Serial.println(Y[j]);
delay(100);
int Push_button;
Push_button=digitalRead(pushbutton);// read pushbutton value
// Check if the stored values exceeded the threshold (88%)
//or the pushbutton is pressed to transmit "One" to Arduino Uno
//delay(50);
if ((Y[0]<88 && Y[1]<88 && Y[2]<88)|| Push_button==1)
const char *msg = “One”;
rf_driver.send((uint8_t *)msg, strlen(msg));
rf_driver.waitPacketSent();
delay (1000);
// Message Transmitted
Serial.println("Message Transmitted: ");
