Hi everyone, I need to use MAX30102 and 2.4 TFT touchscreen LCD to run the project, however the LCD has occupied the pins of SDA and SCL that MAX30102 require to use, can both connect together or need to separate , if separate any pins that suggested to use?
is the LCD screen using I2C to communicate? if so both can communicate on the same bus each will have its own address which can be read using a simple sketch on your arduino.
