MAX30102 is not working With ESP32 DEVkit V1
Hi, please can you tell me how the code is working? I use the "sparkfun electronics" code which is available in arduino library. I use that code but it is not working with MAX30102 sensor. data read and value is generation complete but the SPO2 values are hang around 100,99,98 only and the heart rate values are 150-160 approx. I paste the code here.
"max30105.h file" -> work on both MAX30105 and Max30102 as per the "sparkfun" statement
This is a library written for the Maxim MAX30105 Optical Smoke Detector
It should also work with the MAX30102. However, the MAX30102 does not have a Green LED.
These sensors use I2C to communicate, as well as a single (optional)
interrupt line that is not currently supported in this driver.
Written by Peter Jansen and Nathan Seidle (SparkFun)
BSD license, all text above must be included in any redistribution.
#pragma once
#if (ARDUINO >= 100)
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include <Wire.h>
#define MAX30105_ADDRESS 0x57 //7-bit I2C Address
//Note that MAX30102 has the same I2C address and Part ID
#define I2C_SPEED_STANDARD 100000
#define I2C_SPEED_FAST 400000
//Define the size of the I2C buffer based on the platform the user has
#if defined(AVR_ATmega328P) || defined(AVR_ATmega168)
//I2C_BUFFER_LENGTH is defined in Wire.H
#define I2C_BUFFER_LENGTH BUFFER_LENGTH
#elif defined(SAMD21G18A)
//SAMD21 uses RingBuffer.h
#define I2C_BUFFER_LENGTH SERIAL_BUFFER_SIZE
#else
//The catch-all default is 32
#define I2C_BUFFER_LENGTH 32
#endif
class MAX30105 {
public:
MAX30105(void);
boolean begin(TwoWire &wirePort = Wire, uint32_t i2cSpeed = I2C_SPEED_STANDARD, uint8_t i2caddr = MAX30105_ADDRESS);
uint32_t getRed(void); //Returns immediate red value
uint32_t getIR(void); //Returns immediate IR value
uint32_t getGreen(void); //Returns immediate green value
bool safeCheck(uint8_t maxTimeToCheck); //Given a max amount of time, check for new data
// Configuration
void softReset();
void shutDown();
void wakeUp();
void setLEDMode(uint8_t mode);
void setADCRange(uint8_t adcRange);
void setSampleRate(uint8_t sampleRate);
void setPulseWidth(uint8_t pulseWidth);
void setPulseAmplitudeRed(uint8_t value);
void setPulseAmplitudeIR(uint8_t value);
void setPulseAmplitudeGreen(uint8_t value);
void setPulseAmplitudeProximity(uint8_t value);
void setProximityThreshold(uint8_t threshMSB);
//Multi-led configuration mode (page 22)
void enableSlot(uint8_t slotNumber, uint8_t device); //Given slot number, assign a device to slot
void disableSlots(void);
// Data Collection
//Interrupts (page 13, 14)
uint8_t getINT1(void); //Returns the main interrupt group
uint8_t getINT2(void); //Returns the temp ready interrupt
void enableAFULL(void); //Enable/disable individual interrupts
void disableAFULL(void);
void enableDATARDY(void);
void disableDATARDY(void);
void enableALCOVF(void);
void disableALCOVF(void);
void enablePROXINT(void);
void disablePROXINT(void);
void enableDIETEMPRDY(void);
void disableDIETEMPRDY(void);
//FIFO Configuration (page 18)
void setFIFOAverage(uint8_t samples);
void enableFIFORollover();
void disableFIFORollover();
void setFIFOAlmostFull(uint8_t samples);
//FIFO Reading
uint16_t check(void); //Checks for new data and fills FIFO
uint8_t available(void); //Tells caller how many new samples are available (head - tail)
void nextSample(void); //Advances the tail of the sense array
uint32_t getFIFORed(void); //Returns the FIFO sample pointed to by tail
uint32_t getFIFOIR(void); //Returns the FIFO sample pointed to by tail
uint32_t getFIFOGreen(void); //Returns the FIFO sample pointed to by tail
uint8_t getWritePointer(void);
uint8_t getReadPointer(void);
void clearFIFO(void); //Sets the read/write pointers to zero
//Proximity Mode Interrupt Threshold
void setPROXINTTHRESH(uint8_t val);
// Die Temperature
float readTemperature();
float readTemperatureF();
// Detecting ID/Revision
uint8_t getRevisionID();
uint8_t readPartID();
// Setup the IC with user selectable settings
void setup(byte powerLevel = 0x1F, byte sampleAverage = 4, byte ledMode = 3, int sampleRate = 400, int pulseWidth = 411, int adcRange = 4096);
// Low-level I2C communication
uint8_t readRegister8(uint8_t address, uint8_t reg);
void writeRegister8(uint8_t address, uint8_t reg, uint8_t value);
private:
TwoWire *_i2cPort; //The generic connection to user's chosen I2C hardware
uint8_t _i2caddr;
//activeLEDs is the number of channels turned on, and can be 1 to 3. 2 is common for Red+IR.
byte activeLEDs; //Gets set during setup. Allows check() to calculate how many bytes to read from FIFO
uint8_t revisionID;
void readRevisionID();
void bitMask(uint8_t reg, uint8_t mask, uint8_t thing);
#define STORAGE_SIZE 4 //Each long is 4 bytes so limit this to fit on your micro
typedef struct Record
uint32_t red[STORAGE_SIZE];
uint32_t IR[STORAGE_SIZE];
uint32_t green[STORAGE_SIZE];
byte head;
byte tail;
} sense_struct; //This is our circular buffer of readings from the sensor
sense_struct sense;
This is the C code
Optical SP02 Detection (SPK Algorithm) using the MAX30105 Breakout
By: Nathan Seidle @ SparkFun Electronics
Date: October 19th, 2016
github.com/.../MAX30105_Breakout
This demo shows heart rate and SPO2 levels.
It is best to attach the sensor to your finger using a rubber band or other tightening
device. Humans are generally bad at applying constant pressure to a thing. When you
press your finger against the sensor it varies enough to cause the blood in your
finger to flow differently which causes the sensor readings to go wonky.
This example is based on MAXREFDES117 and RD117_LILYPAD.ino from Maxim. Their example
was modified to work with the SparkFun MAX30105 library and to compile under Arduino 1.6.11
Please see license file for more info.
Hardware Connections (Breakoutboard to Arduino):
-5V = 5V (3.3V is allowed)
-GND = GND
-SDA = A4 (or SDA)
-SCL = A5 (or SCL)
-INT = Not connected
The MAX30105 Breakout can handle 5V or 3.3V I2C logic. We recommend powering the board with 5V
but it will also run at 3.3V.
#include <Wire.h>
#include "MAX30105.h"
#include "spo2_algorithm.h"
MAX30105 particleSensor;
#define MAX_BRIGHTNESS 255
//Arduino Uno doesn't have enough SRAM to store 100 samples of IR led data and red led data in 32-bit format
//To solve this problem, 16-bit MSB of the sampled data will be truncated. Samples become 16-bit data.
uint16_t irBuffer[100]; //infrared LED sensor data
uint16_t redBuffer[100]; //red LED sensor data
#else
uint32_t irBuffer[100]; //infrared LED sensor data
uint32_t redBuffer[100]; //red LED sensor data
#endif
int32_t bufferLength; //data length
int32_t spo2; //SPO2 value
int8_t validSPO2; //indicator to show if the SPO2 calculation is valid
int32_t heartRate; //heart rate value
int8_t validHeartRate; //indicator to show if the heart rate calculation is valid
byte pulseLED = 22; //Must be on PWM pin
byte readLED = 21; //Blinks with each data read
Serial.begin(115200); // initialize serial communication at 115200 bits per second:
pinMode(pulseLED, OUTPUT);
pinMode(readLED, OUTPUT);
// Initialize sensor
if (!particleSensor.begin(Wire, 400000)) //Use default I2C port, 400kHz speed
Serial.println(F("MAX30105 was not found. Please check wiring/power."));
while (1);
Serial.println(F("Attach sensor to finger with rubber band. Press any key to start conversion"));
while (Serial.available() == 0) ; //wait until user presses a key
Serial.read();
byte ledBrightness = 60; //Options: 0=Off to 255=50mA
byte sampleAverage = 8; //Options: 1, 2, 4, 8, 16, 32
byte ledMode = 2; //Options: 1 = Red only, 2 = Red + IR, 3 = Red + IR + Green
byte sampleRate = 100; //Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
int pulseWidth = 411; //Options: 69, 118, 215, 411
int adcRange = 4096; //Options: 2048, 4096, 8192, 16384
particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange); //Configure sensor with these settings
bufferLength = 100; //buffer length of 100 stores 4 seconds of samples running at 25sps
//read the first 100 samples, and determine the signal range
for (byte i = 0 ; i < bufferLength ; i++)
while (particleSensor.available() == false) //do we have new data?
particleSensor.check(); //Check the sensor for new data
redBuffer[i] = particleSensor.getRed();
irBuffer[i] = particleSensor.getIR();
particleSensor.nextSample(); //We're finished with this sample so move to next sample
Serial.print(F("red="));
Serial.print(redBuffer[i], DEC);
Serial.print(F(", ir="));
Serial.println(irBuffer[i], DEC);
//calculate heart rate and SpO2 after first 100 samples (first 4 seconds of samples)
maxim_heart_rate_and_oxygen_saturation(irBuffer, bufferLength, redBuffer, &spo2, &validSPO2, &heartRate, &validHeartRate);
//Continuously taking samples from MAX30102. Heart rate and SpO2 are calculated every 1 second
while (1)
//dumping the first 25 sets of samples in the memory and shift the last 75 sets of samples to the top
for (byte i = 25; i < 100; i++)
redBuffer[i - 25] = redBuffer[i];
irBuffer[i - 25] = irBuffer[i];
//take 25 sets of samples before calculating the heart rate.
for (byte i = 75; i < 100; i++)
  digitalWrite(readLED, !digitalRead(readLED)); //Blink onboard LED with every data read
  //send samples and calculation result to terminal program through UART
  Serial.print(irBuffer[i], DEC);
  Serial.print(F(", HR="));
  Serial.print(heartRate, DEC);
  Serial.print(F(", HRvalid="));
  Serial.print(validHeartRate, DEC);
  Serial.print(F(", SPO2="));
  Serial.print(spo2, DEC);
  Serial.print(F(", SPO2Valid="));
  Serial.println(validSPO2, DEC);
//After gathering 25 new samples recalculate HR and SP02
If you know what's wrong then please tell me
First learn how to use the forum, details at HERE
I am very sorry. I am new here.
Thank you for giving me the guidance. I will correct everything according to this.
No problem, we were all new at one time.
I moved your topic to a more appropriate forum category @arpan222.
The Nano ESP32 category you chose is only used for discussions directly related to the Arduino Nano ESP32 board.
In the future, please take the time to pick the forum category that best suits the subject of your question. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Thanks in advance for your cooperation.
