MAX30102 not lighting up with ESP32
I used MAX30102 with ESP32 following these connections:
sensor Esp pins
Vin Vin (3.3V)
SDA D21 (SDA)
SCL D22 (SCL)
GRD GRD
before it was working fine but now it's not lighting up..... what might be the problem?
MAX30102 with 128,32 LCD screen has been wired and connected
scl with A5 and SDA with A4 but it works fine and currently I want to add ESP32 with it
I hope it works with you
it was working fine untill I used this code;
#define BLYNK_PRINT Serial
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
#include <Wire.h>
#include "MAX30105.h" //sparkfun MAX3010X library
#include "heartRate.h"
SimpleTimer timer;
MAX30105 particleSensor;
char auth[] = "fIGPsYeI0rf2DWG6FAPXdf-NGuhaF0Fe";
char ssid[] = "vivo 1713";
char pass[] = "fab123456";
#define INTERVAL_MESSAGE2 60000
unsigned long time_2 = 0;
int period = 2000;
unsigned long time_now = 0;
double avered = 0;
double aveir = 0;
double sumirrms = 0;
double sumredrms = 0;
int i = 0;
int Num = 100; //calculate SpO2 by this sampling interval
int oxygen;
double ESpO2 = 95.0;    //initial value of estimated SpO2
double FSpO2 = 0.7;     //filter factor for estimated SpO2
double frate = 0.95;    //low pass filter for IR/red LED value to eliminate AC component
#define TIMETOBOOT 3000 // wait for this time(msec) to output SpO2
#define SCALE 88.0      //adjust to display heart beat and SpO2 in the same scale
#define SAMPLING 5      //if you want to see heart beat more precisely , set SAMPLING to 1
#define FINGER_ON 3000  // if red signal is lower than this , it indicates your finger is not on the sensor
#define MINIMUM_SPO2 0.0
const byte RATE_SIZE = 4; //Increase this for more averaging. 4 is good.
byte rates[RATE_SIZE];    //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0; //Time at which the last beat occurred
float beatsPerMinute;
int beatAvg;
#define USEFIFO
  Serial.println("Initializing...");
  Blynk.begin(auth, ssid, pass);
  // Initialize sensor
  while (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
    Serial.println("MAX30102 was not found. Please check wiring/power/solder jumper at MH-ET LIVE MAX30102 board. ");
    //while (1);
  Serial.println("Place your index finger on the sensor with steady pressure.");
  //Setup to sense a nice looking saw tooth on the plotter
  byte ledBrightness = 255; // 0x7F Options: 0=Off to 255=50mA
  byte sampleAverage = 4;   //Options: 1, 2, 4, 8, 16, 32
  byte ledMode = 2;         //Options: 1 = Red only, 2 = Red + IR, 3 = Red + IR + Green
  int sampleRate = 400;     //1000 is best but needs processing power//Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
  int pulseWidth = 411;     //Options: 69, 118, 215, 411
  int adcRange = 16384;     //Options: 2048, 4096, 8192, 16384
  // Set up the wanted parameters
  particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange); //Configure sensor with these settings
  particleSensor.enableDIETEMPRDY();
  timer.setInterval(500, sendUptime);
void sendUptime()
  Blynk.virtualWrite(V4, oxygen);
  //Blynk.virtualWrite(V5, beatAvg);
  Blynk.run();
  timer.run(); // Initiates SimpleTimer
  uint32_t ir, red, green;
  double fred, fir;
  double SpO2 = 0; //raw SpO2 before low pass filtered
#ifdef USEFIFO
  particleSensor.check(); //Check the sensor, read up to 3 samples
  while (particleSensor.available())
  { //do we have new data
#ifdef MAX30105
    red = particleSensor.getFIFORed(); //Sparkfun's MAX30105
    ir = particleSensor.getFIFOIR();   //Sparkfun's MAX30105
#else
    red = particleSensor.getFIFOIR(); //why getFOFOIR output Red data by MAX30102 on MH-ET LIVE breakout board
    ir = particleSensor.getFIFORed(); //why getFIFORed output IR data by MAX30102 on MH-ET LIVE breakout board
#endif
    i++;
    fred = (double)red;
    fir = (double)ir;
    avered = avered * frate + (double)red * (1.0 - frate); //average red level by low pass filter
    aveir = aveir * frate + (double)ir * (1.0 - frate);    //average IR level by low pass filter
    sumredrms += (fred - avered) * (fred - avered);        //square sum of alternate component of red level
    sumirrms += (fir - aveir) * (fir - aveir);             //square sum of alternate component of IR level
    if ((i % SAMPLING) == 0)
    { //slow down graph plotting speed for arduino Serial plotter by thin out
      if (millis() > TIMETOBOOT)
        if (ir < FINGER_ON)
          ESpO2 = MINIMUM_SPO2; //indicator for finger detached
        //float temperature = particleSensor.readTemperatureF();
        if (ESpO2 <= -1)
          ESpO2 = 0;
        if (ESpO2 > 100)
          ESpO2 = 100;
        oxygen = ESpO2;
        Serial.print(" Oxygen % = ");
        Serial.println(oxygen);
    if ((i % Num) == 0)
      double R = (sqrt(sumredrms) / avered) / (sqrt(sumirrms) / aveir);
      // Serial.println(R);
      SpO2 = -23.3 * (R - 0.4) + 100;               //http://ww1.microchip.com/downloads/jp/AppNotes/00001525B_JP.pdf
      ESpO2 = FSpO2 * ESpO2 + (1.0 - FSpO2) * SpO2; //low pass filter
      //Serial.print(SpO2); Serial.print(","); Serial.println(ESpO2);
      sumredrms = 0.0;
      sumirrms = 0.0;
      i = 0;
    particleSensor.nextSample(); //We're finished with this sample so move to next sample
    //Serial.println(SpO2);
  long irValue = particleSensor.getIR();
  Serial.println(irValue);
  if (millis() > time_2 + INTERVAL_MESSAGE2 && oxygen < 93)
    time_2 = millis();
    Blynk.notify("Alert! Oxygen Saturation below 93% Detected");
    Serial.print("Alert called");
#endif
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
So you had another code and things were working and now you got some new code and things are not working, correct?
What does not working mean?
Post several images of you wiring. Post a schematic.
What maths are you using that requires doubles with an ESP32?
Do you get that message?
Does this produce a printout and if so which one?
You've got to give up a lot more info and post pictures of your wiring and power supply.
And, what the heck does not working mean?
