i used an ic2 scanner to verify the module is functional, and it says:
"17:10:45.780 -> Scanning...
17:10:45.780 -> I2C device found at address 0x57 !
17:10:45.780 -> done"
however, when i plug it into the sparkfun libraries example sketch, it is not recognized. is there any way to fix this?
- Please read How to get the best out of this forum
- Post your sketch.
RV mineirin
#include <Wire.h>
#include "MAX30105.h"
MAX30105 particleSensor;
#define debug Serial //Uncomment this line if you're using an Uno or ESP
//#define debug SerialUSB //Uncomment this line if you're using a SAMD21
debug.begin(9600);
debug.println("MAX30105 Basic Readings Example");
// Initialize sensor
if (particleSensor.begin() == false)
debug.println("MAX30105 was not found. Please check wiring/power. ");
while (1);
particleSensor.setup(); //Configure sensor. Use 6.4mA for LED drive
debug.print(" R[");
debug.print(particleSensor.getRed());
debug.print("] IR[");
debug.print(particleSensor.getIR());
debug.print("] G[");
debug.print(particleSensor.getGreen());
debug.print("]");
debug.println();
keeps saying not recogized. maybe becuse i am using mega and not the regular arduino uno
Which arduino/ESP are you using?
i am using arduino mega 2560.
Replace this line :
with this one:
if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
i'm sorry but it says it is not found. the sensor board did not flash either
