Hi, I using the MAX30102 and run with the SparkFun MAX 3010x Pulse and Proximity Sensor Library, but I still cannot obtain a simple basic reading in serial monitor. I ensure the wiring are connect correctly but the serial monitor still pop out the message MAX30105 was not found. Please check wiring/power. Can somebody help me, thank you so much.
MAX30105 Breakout: Output all the raw Red/IR/Green readings
By: Nathan Seidle @ SparkFun Electronics
Date: October 2nd, 2016
https://github.com/sparkfun/MAX30105_Breakout
Outputs all Red/IR/Green values.
Hardware Connections (Breakoutboard to Arduino):
-5V = 5V (3.3V is allowed)
-GND = GND
-SDA = A4 (or SDA)
-SCL = A5 (or SCL)
-INT = Not connected
The MAX30105 Breakout can handle 5V or 3.3V I2C logic. We recommend powering the board with 5V
but it will also run at 3.3V.
This code is released under the MIT License.
#include <Wire.h>
#include "MAX30105.h"
MAX30105 particleSensor;
#define debug Serial //Uncomment this line if you're using an Uno or ESP
//#define debug SerialUSB //Uncomment this line if you're using a SAMD21
debug.begin(9600);
debug.println("MAX30105 Basic Readings Example");
// Initialize sensor
if (particleSensor.begin() == false)
debug.println("MAX30105 was not found. Please check wiring/power. ");
while (1);
particleSensor.setup(); //Configure sensor. Use 6.4mA for LED drive
debug.print(" R[");
debug.print(particleSensor.getRed());
debug.print("] IR[");
debug.print(particleSensor.getIR());
debug.print("] G[");
debug.print(particleSensor.getGreen());
debug.print("]");
debug.println();
