MAX31856 Causing input state change lag.
Hi Everyone,
This is my first project so I am sure there is something simple I don't understand. Any thoughts or suggestions will be greatly appreciated. Thanks
I am working on creating a PID temp controller. I am using a MAX31856 with a J type T/C as the temp sensor. I am using two push buttons. (yes, I am using the internal pull up resistors) One to increase and one to decrease the set point. All printing out to the standard 16x2 LCD. Before I added the code to read actual temperature using the MAX31856, the response of buttons was instantaneous. As fast as I can press the buttons the display would keep up. I added the code and got the sensor to output and display the actual ambient temp just fine, but once I added the code for the MAX31856 the buttons only change the set point at a rate of about 1/sec.
I have commented out the code for the sensor and the sensor still wired and the buttons response returns to normal. As soon as I uncomment the code the buttons response time returns. I removed wiring and hardware and left the code in and I got the same results. I looked through the src and header files for the MAX31856 library, I don't see any obvious causes.
The MAX31856 uses 4 wire SPI to connect to the Arduino uno I am using. I am using pins (10, 11, 12, 13)
Below is my code followed. Attached is the MAX31856 library I got from the library manager.
#include <Adafruit_Sensor.h>
#include <Adafruit_MAX31856.h>
#include <LiquidCrystal.h>
// Constants
const int decreaseButtonPin = 7;    // the # of the decrease push button pin
const int increaseButtonPin = 8;    // the # of the increase push button pin
// Non-Const Global
int decreaseButtonState;     // the current state of the decrease push button
int increaseButtonState;     // the current state of the increase push button pin
int dLastButtonState = LOW;  // the previous reading of decrease push button pin
int iLastButtonState = LOW;  // the previous reading of increase push button pin
int tempSetPoint = 32;       // the # of times button was pressed since last reset
int setPointLowLimit = 32;   // the low limit for the temp setpoint
int setPointHighLimit = 250; // the high limit for the temp setpoint
// long is used because time in millisecs with grow quickly
unsigned long lastDebounceTime = 50;   // the last time the output pin was toogled
unsigned long debounceDelay = 0;       // the debounce time in millisecs increase if the output flickers
//Intialize the library with the numbers of the interface pins
LiquidCrystal lcd(9, 6, 5, 4, 3, 2);
Adafruit_MAX31856 maxthermo = Adafruit_MAX31856(10, 11, 12, 13);
   // Setup for MAX31586
   Serial.begin(115200);   // set the baud rate and intialized serial comms
  maxthermo.begin();      // creates an MAX31586 object
  maxthermo.setThermocoupleType(MAX31856_TCTYPE_J);   // Configures for J Type T/C
   // Configures the Push Buttons
   pinMode(increaseButtonPin, INPUT_PULLUP);   // Pin #8
   pinMode(decreaseButtonPin, INPUT_PULLUP);   // Pin #7
   // Initialize the LCD Display
   // set up the LCD's number of columns and rows:
   lcd.begin(16, 2);        // set up the LCD's number of columns and rows
   lcd.print("TEMP: ");     // Prints header on first line
   lcd.setCursor(0, 1);     // Set Cursor on the new line
   lcd.print("SETPOINT: "); // Prints header on second line
   // Variables
   int iButtonReading = digitalRead(increaseButtonPin);   // read the state of increase button into iButtonReading
   int dButtonReading = digitalRead(decreaseButtonPin);   // read the state of the decrease button into dButtonReading
  int actualTemp = maxthermo.readThermocoupleTemperature();   // the actual temp read from the sensor
    *  check to see if either button was just pressed
    *  (i.e. the input went from LOW to HIGH), and you've waited long enough
    *  since the last press to ignore any noise:
   // If either of the button states changed, due to noise or pressing:
   if (iButtonReading != iLastButtonState || dButtonReading != dLastButtonState) {
     // lastDebounceTime = millis();   // Then reset the decouncing timer
   //  If the reading has been there for longer than the debounce
   if ((millis() - lastDebounceTime) > debounceDelay) {
      // Then delay, so take it as the actual current state
      //If the increase button state has changed
      if (iButtonReading != increaseButtonState) {
         increaseButtonState = iButtonReading;  // Then take the new state
         // If the increase button state is HIGH & the setpoint is less than the setpoint high limit
         if (increaseButtonState == LOW && setPointHighLimit > tempSetPoint) {
            tempSetPoint = tempSetPoint + 1;   // Then increase the setPoint by 1
    // If the decrease button state has changed
    if (dButtonReading != decreaseButtonState) {
         decreaseButtonState = dButtonReading;   // Then take the new state
         // If decreaseed button state is HIGH & the setpoint is greater than the setpoint low limit
         if (decreaseButtonState == LOW && tempSetPoint > setPointLowLimit) {
            // Then decrease the setpoint by 1
            tempSetPoint = tempSetPoint - 1;
  * Print current setpoint and actual temp to the LCD
  lcd.setCursor(6, 0);                               // Sets the cursor after the "Temp: " header
  int actualTempInF = (actualTemp / (5/9.0) + 32);   // Removes the decimal from the display
  lcd.print(actualTempInF);                          // Prints actual temp in degrees F
  lcd.print((char)223);                              // Degree symbol
  lcd.print("F");
  lcd.setCursor(10, 1);
  lcd.print(tempSetPoint);
  lcd.print("F");
  // save the reading. Next time trough the loop, it'll be the lastButtonState
  iLastButtonState = iButtonReading;
  dLastButtonState = dButtonReading;
Adafruit_MAX31856.cpp (10 KB)
Adafruit_MAX31856.h (5.13 KB)
Please post the sketch where you have commented out the sensor read code and had the buttons return to the expected responsiveness.
Here is my code with the sensor SPI read commented out. I verified that this code allows the buttons to behave as expected. When I remove that line of code the button responds as expected.
Could the SPI read cause inference on other input pins, and if so what are so possible remedies?
// Constants
// Non-Const Global
   // Initalize the LCD Display
   // Variables
*   Removed to return button to expected responsiveness
*   float actualTemp = maxthermo.readThermocoupleTemperature();   // the actual temp read from the sensor
   lcd.setCursor(6, 0);// Sets the cursor after the "Temp: " header
*  Removed to return buttons to expected responsiveness
*  int actualTempInF = (actualTemp / (5/9.0) + 32);   // Removes the decimal from the display
*  lcd.print(actualTempInF);                            // Prints actual temp in degrees F
   lcd.print("F");
   lcd.print("F");
