MAX31856 error
Hello,
I am trying to test max31856 thermocouple amplifier with type T thermocouples. I have specified in the code that the thermocouple attached is type T, but whenever I go to the serial monitor to view the outputs, it reads as shown in the attached file. Has anyone had this problem before? Any suggestions?
Here is my code:
#include <Adafruit_MAX31856.h>
// Use software SPI: CS, DI, DO, CLK
Adafruit_MAX31856 maxthermo = Adafruit_MAX31856(10, 11, 12, 13);
// use hardware SPI, just pass in the CS pin
//Adafruit_MAX31856 maxthermo = Adafruit_MAX31856(10);
  Serial.println("MAX31856 thermocouple test");
  maxthermo.begin();
  maxthermo.setThermocoupleType(MAX31856_TCTYPE_T);
  Serial.print("Thermocouple type: ");
  switch (maxthermo.getThermocoupleType() ) {
    case MAX31856_TCTYPE_B: Serial.println("B Type"); break;
    case MAX31856_TCTYPE_E: Serial.println("E Type"); break;
    case MAX31856_TCTYPE_J: Serial.println("J Type"); break;
    case MAX31856_TCTYPE_K: Serial.println("K Type"); break;
    case MAX31856_TCTYPE_N: Serial.println("N Type"); break;
    case MAX31856_TCTYPE_R: Serial.println("R Type"); break;
    case MAX31856_TCTYPE_S: Serial.println("S Type"); break;
    case MAX31856_TCTYPE_T: Serial.println("T Type"); break;
    case MAX31856_VMODE_G8: Serial.println("Voltage x8 Gain mode"); break;
    case MAX31856_VMODE_G32: Serial.println("Voltage x8 Gain mode"); break;
    default: Serial.println("Unknown"); break;
  Serial.print("Cold Junction Temp: ");
  Serial.println(maxthermo.readCJTemperature());
  Serial.print("Thermocouple Temp: ");
  Serial.println(maxthermo.readThermocoupleTemperature());
  // Check and print any faults
  uint8_t fault = maxthermo.readFault();
  if (fault) {
    if (fault & MAX31856_FAULT_CJRANGE) Serial.println("Cold Junction Range Fault");
    if (fault & MAX31856_FAULT_TCRANGE) Serial.println("Thermocouple Range Fault");
    if (fault & MAX31856_FAULT_CJHIGH)  Serial.println("Cold Junction High Fault");
    if (fault & MAX31856_FAULT_CJLOW)   Serial.println("Cold Junction Low Fault");
    if (fault & MAX31856_FAULT_TCHIGH)  Serial.println("Thermocouple High Fault");
    if (fault & MAX31856_FAULT_TCLOW)   Serial.println("Thermocouple Low Fault");
    if (fault & MAX31856_FAULT_OVUV)    Serial.println("Over/Under Voltage Fault");
    if (fault & MAX31856_FAULT_OPEN)    Serial.println("Thermocouple Open Fault");
Please post a link (using the chain links icon on the forum toolbar to make it clickable) to where you downloaded that library from. Or if you installed it using Library Manger (Sketch > Include Library > Manage Libraries in the Arduino IDE or Libraries > Library Manager in the Arduino Web Editor) then say so and state the full name of the library.
Adafruit MAX31856 library was installed using library manager
Has anyone encountered this error using MAX31856 before? I am using type T thermocouples. I have attached an image of the error.
Library downloaded from library manger: Adafruit MAX31856 library
  maxthermo.begin();
  if (fault) {
Please don't post multiple times...
I am experiencing a similar issue on Arduino Uno with Adafruit Max 31856 using Adafruit's max31856 library.
Despite using: maxthermo.setThermocoupleType(MAX31856_TCTYPE_K), (and other options) getThermocoupleType() always returns B.
Removing the setThermocoupleType() function from my script, the default K type should be set. No luck.. always Type B (0) is returned.
Have triple checked wiring, tried software and hardware SPI.
Have had no luck connecting Max to Pi Zero SPI either (with Adafruit library), despite having working Pi Zero SPI coms with ATmeta 1284 (multiple slaves). Seems weird to me.
I’ve been facing the same issue here.
