MAX31856 + SD card logger issue
Hello all,
I have a logger which I made with an Arduino Nano, a MAX31856 and a SD card.
If I use the MAX31856 without writing the temperature on the SD card, everything works fine.
If I write some data in a file on SD card, everything works fine.
If I try to read the temperature from the MAX and write it in a file on SD card....nothing is written. There is no readout from the MAX device actually.
I suspect something related with the SPI modes.
As far as I know, the MAX is working with SPI_MODE1 and the SD card with SPI_MODE0.
However, I cannot make them work together.
Any ideas?
Thanks.
Hope this helps.
