Hello everyone,
I got myself a breakout board, named MAX31865 Dual PT-100 RTD (this one: Playing With Fusion - Dual PT100 RTD Temperature Sensor SPI Digital Interface MAX3186 Breakout). I connected it with the Tinxi NodeMcu v1 in order to send temp values via WIFI to my java program.
The webserver is running without any problems, but I have so far been unable to get any values from the MAX31865... I first tried using the MAX31865 library (attached .cpp/.h) and the example code of it (attached file) but the only value I got is an error message: 255 high threshold...why??
Concerning the wiring: NodeMCU - MAX31865
GND - GND
3V3 - VIN
SD0 - SD0
D1 - CS1
CLK - SCLK
SD1 - SD1
D0 - CS2
Please be patient with my knowledge, I'm a newbee at this sector If there are any other questions please ask!
Setup:
- PT100 (2-Wire; if working a 4-Wire will be used)
- MAX31865
- NodeMcu v1 esp8266
nodemcu_server_read.ino (2.1 KB)
MAX31865.cpp (6.89 KB)
MAX31865.h (4.54 KB)
