http://datasheets.maxim-ic.com/en/ds/MAX395.pdf
8-channel, serially controlled, single-pole/single-
throw (SPST) analog switch
I snagged this ic in the hopes of expanding the outputs of my Arduino. Am I barking up the wrong tree?
I was under the impression that I would be able to feed this switch's inputs w 5.5 and then send a high/low value by triggering the switch for any of the 8 pins.
I realize I will need the spi library and the code to make it actually work, I'm looking for input if this is a viable solution before I try to figure all of it out to no end. I don't mind trying it out if noone else has though, just figured it was worth a quick query. :-/
