Max485 modbus rtu
Hello, I bought a ttl to rs 485 converter to be able to read and write over arduino unoda rs 485, but I can't read, there are useless resources, can someone help, if there is a code that I can read and print data at least in the modbus pool about the connections and sample codes to be made, the room will be useful for me
I moved your topic to an appropriate forum category @murat913.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
hello first of all thank you for your attention excuse me it was the first question i posted on the forum i will definitely pay attention to it in the future .
Q1: What have you tried so far?
Q2: What code are you using? --> post it to the forum in code tags
Q3: What doesn't work? Post the error message or describe what happens currently and what you would expect to get instead.
Q4: Which device do you want to read from? --> Link to the datasheet/description of modbus registers of that device.
Q5: What Microcontroller are you using? --> Link to it
Q6: How does your schematic look like? Post a schematic and real pictures of your setup so we can see each module/wire/connection.
If you answer all 6 questions someone can help you.
