MAX6675-library
How would I use two sensors with this library? I have one temperature sensor working, but I can not figure out how to read the temperature from two sensors. I have tested them separately and they work. Also, i'm using the proper MAX6675 chip not the other newer one.
https://github.com/adafruit/MAX6675-library
http://learn.adafruit.com/thermocouple/
Thanks!
you need to define 2 sets of pins in your code, (The serial example defines one set) one set for sensor one, and a second set for sensor two..
