MAX6675 using nan as feedback
Hi All,
I have an application where I am using multiple MAX6675 sensors which work great but I'm trying to write in some troubleshooting code...
The sensors are in a temperature controlled environment that will never go below zero and from my experience with the sensors they respond with a '0.00' if the thermocouple is disconnected so I have a 'multiple zero check' in code which works great.
The issue that I have is when the sensor/board has a fault it typically responds 'nan'... how do I run a check against nan?
Zero is easy enough to check
float tempRead = tempSensor.readCelsius();
if (tempRead == 0.00){
    //Loop read to ensure not 'one off'
    //Thermocouple Error Code
but obviously
if (tempRead == nan){
    //Sensor error code
would not compile as it won't know what 'nan' is... (I tried anyway and got the result I expected).
How can I read/store/use 'nan' to my advantage or is what I'm asking simply not possible?
try uppercase NAN
or better:
if (isnan(tempread)) ...
knut_ny:
try uppercase NAN
or
isnan(tempread)
wow...
the uppercase compiles with no issues and seems to work! Thanks!! Didn't think it would be that simple and I feel so stupid for not trying it!
as NAN is a function, i believe the 'isnan' is the preferred variant
