MAX6675 with Due
Hello, I'm using Type K thermocouple and it was working with Uno, now I'm trying the same code with same library with Due and I get the following error:
Arduino: 1.6.8 (Windows 10), Board: "Arduino Due (Programming Port)"
C:\Program Files (x86)\Arduino\libraries\max6675\max6675.cpp:9:24: fatal error: util/delay.h: No such file or directory
#include <util/delay.h>
compilation terminated.
exit status 1
Error compiling for board Arduino Due (Programming Port).
option enabled in File -> Preferences.
#include "max6675.h"
int thermoDO = 5;   // SO
int thermoCS = 6;   // CS
int thermoCLK = 7;  // SCK
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
  Serial.println("MAX6675 test");
  // wait for MAX chip to stabilize
  // basic readout test, just print the current temp
   Serial.print("C = ");
   Serial.println(thermocouple.readCelsius());
   delay(3000);
Attached is MAX6675-library-master that I'm using
Your help is appreciated :smiley:
MAX6675-library-master.zip (3.98 KB)
I have the same problem. How did you solved it?
Thank you
Remove util/delay.h from the library, this is for an AVR but your board is an ARM.
https://forum.arduino.cc/index.php?topic=19963.0
[// this library is public domain. enjoy!
// www.ladyada.net/learn/sensors/thermocouple
#include <avr/pgmspace.h>
#include <stdlib.h>
MAX6675::MAX6675(int8_t SCLK, int8_t CS, int8_t MISO) {
  sclk = SCLK;
  cs = CS;
  miso = MISO;
  //define pin modes
  pinMode(cs, OUTPUT);
  pinMode(sclk, OUTPUT);
  pinMode(miso, INPUT);
  digitalWrite(cs, HIGH);
double MAX6675::readCelsius(void) {
  uint16_t v;
  digitalWrite(cs, LOW);
  v = spiread();
  v <<= 8;
  v |= spiread();
  if (v & 0x4) {
    // uh oh, no thermocouple attached!
    return NAN;
    //return -100;
  v >>= 3;
  return v*0.25;
double MAX6675::readFahrenheit(void) {
  return readCelsius() * 9.0/5.0 + 32;
byte MAX6675::spiread(void) {
  int i;
  byte d = 0;
  for (i=7; i>=0; i--)
    digitalWrite(sclk, LOW);
    if (digitalRead(miso)) {
      //set the bit to 0 no matter what
      d |= (1 << i);
    digitalWrite(sclk, HIGH);
  return d;
aun que sigue diciendo avr a mi me a funcionado en placas amr en especial stm32fi03c8t6 pero se que también funciona en DUE habres tu libreria cpp cortas lo que contiene lo pegas en un block de notas y pega este e intenta cargar lo yo lo edito con notapad++ pero también debe funcionar cortando y pegando me gustaria saber si te funciono riegosnaturales@gmail.com
