The question of how much current these modules use comes up on a regular basis so I thought I would try an experiment and actually measure the current usage. I used my Parola module (forum discussion) as the test device, but this is similar to the more generic modules and I believe the results are transferable.
The MAX7219 has a resistor that sets the maximum current supplied to the matrix (Rset in the datasheet). My matrix had Rset = 62k, in line with the datasheet suggested values. I know that some of the cheap generic modules have very low values for Rset, which would significantly increase the power/current required by the module.
A digital multimeter was used to measure the current into the module (ie, nothing special).
Results were not surprising, but confirmed by the measured data:
The current was linearly proportional to the number of LEDs lit, irrespective of whether the LEDs were rows or columns. I ended up discarding the values for columns due to this symmetry.
The current was linearly proportional to the intensity setting of the LEDs.
With no LEDs lit the current drawn was 2.6mA and with all LEDs at maximum brightness setting it was around 67mA. This last value was surprising as it is considerably less than the often-quoted 200mA per module. I expect that Rset comes into play in a significant way at this extreme end.
marco_c:
How is that specifically "in line" with the datasheet? The datasheet offers a wide variety.
marco_c:
Certainly would. Normally 10k for the eBay specials, for a segment current somewhat in excess of 40 mA (well within specs for both the MAX7219 and most 8 by 8 LED matrices), the specified minimum value for RSET being 9.53kΩ. ( )
marco_c:
How could this possibly be surprising? According to Table 11, given a segment voltage (red) of say, 2.5V (albeit I would actually expect it to be lower, under 2V), RSET of 62k gives a segment current of just under 10 mA, eight times which would be 80 mA. 67 mA sounds close enough to me, no surprises at all.
A fully lit matrix with a 10k RSET though would arguably draw 320 to 350 mA, still within specs. (Not tried here. For simple experimentation I have never found full brightness to be necessary, and you cannot then use multiple modules - I generally play with three - with USB.)
Using the PWM function to operate the matrix at lower brightness levels means that this is also the peak current, which is why that 10µF (or better) bypass capacitor on each MAX7219 is so critical.
I run 8 (2 by 4) modules (on USB) ALL the time and my current peaks at .61A (with ALL 512 LEDs lit, on medium intensity). I started a thread a while ago asking for confirmation(or repudiation) of my current usages but nobody seemed to be interested.
I came away with the suggestion that current should only be measured with an osciloscope not the cheap ammeter that I had.
Till then I was faced with the usual claims of 170ma (sometimes 200ma) per module. I actually bought 2A USB wall chargers to drive my 8 module displays. I have 5 by 4 modules arriving SOON and I intend to play with 12 module displays (maybe 16 module displays?). It is good fun with Marco's libraries....
It is refreshening to see your very professional approach to the situation, Marco.
Hi there
I tried to make a module for a led matrix 8x8 2 inches square, common cathode, red by copying the diagram from the mini 7219 module, but i'm not able to make it work. Does anybody can share gerber files for this project?
Of course i'm a newby.
Thanks in advance.
I just measured mine since they were killing the power to the ESP8266 and Mega, both, just from a computer and from a 9v wall wart, too. I am on brightness 2, which is near the bottom and I am seeing about 600ma with all LEDs on. Running 50-100ma with average number of LEDs on. I will test at full brightness tomorrow to gauge a safety factor for a power supply for two 8x8x8 red matrices. I am figuring, right now, that 10A will be quite sufficient. $10 and I will be good to go.
I put up a Youtube of is. "Dual LED 8x8x8 Display on Arduino et. al.". Running on a PS with a fan and that is a non-starter for the bedroom. Time on one, full time, date, DOY and, maybe, temperature and WX CONDX on the other one, scrolling by. Will see. Anyway, need power. Billions and billion of electrons!
