Working with the R2 builder group on revising a few PCB boards for R2 lights.
These use 3 MAX7219 ICs to control #137 3MM LEDs.
Now the original PCB design didn't have a ground plane, so there was a lot of wasted real estate in creating ground traces on the PCB. I've since then removed all grounds and added a new ground plane, but I'm left wondering about the LED cathodes and if I can clean them up too.
I can see that the MAX7219 has large arrays of LEDS hooked up to SEGXX across the ICs and the cathodes hooked up to DIGXX across the same array.
So my question is, what happens if I disconnect cathodes from DIGXX of IC's and tie them to my new ground plane? Will the IC / LEDs still function as intended, or is digital pins on IC not acting as a ground, but much more?
I ask this without having the actual parts in hand; other wise I would of tested prior to post.
Thank you!
