Hi all,
I am making a 7 segment display array - very similar to the one shown here, except I am making a larger overall display (100 x 4 digit 7 segment displays, 50 x max7219 chips) and using the max7219CWG instead of the max7219CNG (24 Wide SO vs 24 narrow DIP).
The first 20 displays (10 chips) display great and I'm having zero issues. However, once I start trying to get the next few displays to work, they will not turn on. I have discovered that if I put the first few displays into the shutdown mode (i.e turn them off in my code), that the next few displays down the line begin to function. In fact, I have soldered around 40 displays so far (20 chips) and I can get any 11 or 12 chips working that I desire by altering the code alone. This confirmed to me that I haven't soldered anything wrong or messed up my PCB design, but leads me to believe I have an issue with insufficient current.
The author of the post linked above doesn't mention this issue, however admittedly I am attempting a much larger display. But even then, I wouldn't be able to get a display their size working.
The MAX7219 datasheet implies that the max operating current could be as high as 330mA (with all segments on, which is much more than what I am attempting), which I guess makes sense why I am running out of current.
Does anyone know any trick to reduce the current draw of the chips? I'm hoping there's something smart I can do within the code.
The datasheet for the chip can be found here.
I've also appended the current code below for additional information.
Thanks for your help, I appreciate it!
#include <SPI.h>
// What pin on the Arduino connects to the LOAD/CS pin on the MAX7219/MAX7221
#define LOAD_PIN 7
void maxTransfer(uint8_t address, uint8_t value) {
// Ensure LOAD/CS is LOW
digitalWrite(LOAD_PIN, LOW);
SPI.transfer(address);
SPI.transfer(value);
// Tell chip to load in data
digitalWrite(LOAD_PIN, HIGH);
// Set load pin to output
pinMode(LOAD_PIN, OUTPUT);
// Reverse the SPI transfer to send the MSB first
SPI.setBitOrder(MSBFIRST);
// Start SPI
SPI.begin();
// Run test
// All LED segments should light up
maxTransfer(0x0F, 0x01);
maxTransfer(0x0F, 0x00);
// disable mode B
maxTransfer(0x09, 0x00);
// Use lowest intensity
maxTransfer(0x0A, 0x00);
// scan 8 digits
maxTransfer(0x0B, 0x07);
// Turn on chip
maxTransfer(0x0C, 0x01);
// This loop just turns on a single segment at a time in a circular pattern around the perimeter of each display.
int delayspeed = 500;
for (uint8_t i = 1; i < 0x09; ++i)
maxTransfer(i, 0x00);
maxTransfer(0x01, 0b01000000);
delay(delayspeed);
maxTransfer(0x02, 0b01000000);
delay(delayspeed);
maxTransfer(0x03, 0b01000000);
delay(delayspeed);
maxTransfer(0x04, 0b01000000);
delay(delayspeed);
maxTransfer(0x04, 0b00100000);
delay(delayspeed);
maxTransfer(0x04, 0b00010000);
delay(delayspeed);
maxTransfer(0x08, 0b00100000);
delay(delayspeed);
maxTransfer(0x08, 0b00010000);
delay(delayspeed);
maxTransfer(0x08, 0b00001000);
delay(delayspeed);
maxTransfer(0x07, 0b00001000);
delay(delayspeed);
maxTransfer(0x06, 0b00001000);
delay(delayspeed);
maxTransfer(0x05, 0b00001000);
delay(delayspeed);
maxTransfer(0x05, 0b00000100);
delay(delayspeed);
maxTransfer(0x05, 0b00000010);
delay(delayspeed);
maxTransfer(0x01, 0b00000100);
delay(delayspeed);
maxTransfer(0x01, 0b00000010);
delay(delayspeed);
