max7219 DOT MATRIX
Hi, how one can change it capital letterTHNAKS
#include <LedControl.h>
LedControl lc=LedControl(12,11,10,2);
byte A[5]={B11111100,B00100010,B00100010,B00100010,B11111100};
http://forum.arduino.cc/index.php?topic=149017.0
Rather than use code that has the byte arrays that make the characters, in the actual code itself, there are other ways of coding. In these, the data for the characters is stored in a font file that is “attached” to the code so to speak. Nick Gammon and Riva, both members of this forum , have excellent code examples available. Nick’s tutorial is here
and the forum thread mentioning Riva’s code where the full alphabet and other punctuation symbols are included in the code, is at the bottom of reply # 18 (ScrollTest4MAX.ino) here
Note that Nick’s code uses SPI so the connection of the control lines is different.
HI, when I tried to write capital A I could not pls help what to add where & what to remove where exactly
thanks
LedControl lc=LedControl(12,11,10);
ayonis:
Hi, how one can change it capital letter if possible to write QUICK BROWN FOX JUMP OVER THE LAZY DOG
You don't want the letter 'S'?
Hi, I want "S"
thanks
If you want help then post your code correctly. This is your second request for this.
Two members at the same IP address, with similar problems, neither of whom have read the clearly posted forum guidelines.
What are the chances of that, eh?
ento:
hello, I have similar problem I am not sure my code is correct
any body can help.
Read this before posting a programming question
How to use this forum
If you are not capable of posting code correctly you are not capable of understanding any answer we may give.
