Max7219 ewg+t and 1088as not working
Hello,
I have a problem.
I am using an Max7219 ewg+t with an 1088as. I want to build a Clock with these and somehow I got the wrong 1088as I think.
1088as: Matrix LED 8x8 3mm Rot Matrix 16 Pins 64 LED Anzeige 1088AS REF605 | eBay
Max7219 ewg+t: MAX7219EWG+T Maxim Integrated | Mouser Österreich
I noticed that the Max Chip is a common cathode driver chip and the 1088as is common anode.
But the Matrix still lits up at every led. If i try to send a smily face for example, nothing happens. Not even the clear command. I'm using the MaxMatrix Library.
The schematic:
They are stacked side by side 16 times!
I hope someone can help me!
Code of smily face:
#include <MaxMatrix.h>
#define data 8
#define load 9
#define clk 10
#define maxInUse 1
MaxMatrix m(data, load, clk, maxInUse);
  m.init();
  m.setIntensity(3);
  happy();
  delay(5000);
  normal();
  delay(5000);
  sad();
  delay(5000);
  normal();
  delay(5000);
void outline() {
  m.setDot(2,0,1);
  m.setDot(3,0,1);
  m.setDot(4,0,1);
  m.setDot(5,0,1);
  m.setDot(1,1,1);
  m.setDot(6,1,1);
  m.setDot(0,2,1);
  m.setDot(0,3,1);
  m.setDot(0,4,1);
  m.setDot(0,5,1);
  m.setDot(7,2,1);
  m.setDot(7,3,1);
  m.setDot(7,4,1);
  m.setDot(7,5,1);
  m.setDot(1,6,1);
  m.setDot(6,6,1);
  m.setDot(2,7,1);
  m.setDot(3,7,1);
  m.setDot(4,7,1);
  m.setDot(5,7,1);
  m.setDot(2,2,1);
  m.setDot(5,2,1);
void happy() {
  m.clear();
  outline();
  m.setDot(2,4,1);
  m.setDot(5,4,1);
  m.setDot(3,5,1);
  m.setDot(4,5,1);
void normal() {
  m.clear();
  outline();
  m.setDot(2,4,1);
  m.setDot(5,4,1);
  m.setDot(3,4,1);
  m.setDot(4,4,1);
void sad() {
  m.clear();
  outline();
  m.setDot(2,5,1);
  m.setDot(5,5,1);
  m.setDot(3,4,1);
  m.setDot(4,4,1);
I know a bit messy but, it was programmd on the fly.
That is in fact, a meaningless statement. :roll_eyes:
The MAX7219 is simply an 8 by 8 matrix driver. It will drive any 8 by 8 (monochrome) LED matrix if wired correctly. Matrices are simultaneously "common anode" and "common cathode". The 1088AS and 1088BS are complementary. Your schematic is correct for a 1088BS.
To use the 1088AS you would have to exchange cathode and anode connections. For this reason, I do not purchase modules with the matrices soldered in place! :astonished:
What modules are you using and where did you purchase them?
Thanks for the quick awnser!
I have purchased the 1088as at: Matrix LED 8x8 3mm Rot Matrix 16 Pins 64 LED Anzeige 1088AS REF605 | eBay
And the Driver Chips at: MAX7219EWG+T Maxim Integrated | Mouser Österreich
I didn't buy any plug and play Matrix. I designed my own pcb for a Clock that schould display:
(hr/hr/min/min/sec/sec)
(dd/mm/yyyy)
(the day of the week in short(Mon,Thu,Wed,....))
I gues i have to change the connections in the Schematic and then order a new pcb.
Thanks a lot
Well, if you have the wrong combination of display and connections, that would be the only way to go.
I see no point at all in re-inventing the wheel. I just use these:
With an ESP-01 to drive them. :grin:
I know that these things exist but its really hard to intigrate it into a pcb.
Just look:
My uncle heard that I am a hobby electrical engineer and asked if i can make a clock for him. And it would be good if it was in this layout and so on. But I'm gonna make some adjustments.
My point is that there is absolutely no need to make your own PCB if the parts to construct it are already available ready-made and relatively inexpensive. It just makes no sense.
The layout you show is easily constructed from the modules I have cited.
What are the components such as "U4", "U5" on your PCB? I gather they are the capacitors.
