MAX7219 LordPants' library LedControl giving an error ! help ! [SOLVED]
hello guys,
i will start by this link from which i got the library modified of LedControl for common anode 7-segment
https://github.com/deruiter/DCF77-Analyzer-Clock/tree/master/LedControl%20added%20COMMON%20ANODE%20display%20support
so i copied the code and saved it because i couldn't download it directly from the link, this library belongs to LordPants and this is his post about it
so after i saved i went to my code which worked perfectly before saving it, and test it but i am not using CA for test, i am still using the same old circuit for CC 7segment display
and i added the boolean argument he says to add in LedControl() function
but i received this error :
no matching function for call to 'LedControl::LedControl(int, int, int, int, int)'
so can anyone please help with this ?
New Update:
i am getting this error now :
D:\Arduino/MAX7219_count_with_Potentiometer.ino:12: undefined reference to 'LedControl(int, int, int, int, bool)'
thanks in advance to all :slight_smile:
no matching function for call to ‘LedControl::LedControl(int, int, int, int, int)’
Looking at the LedControl() function in the library the error message is right. The function takes 4 ints as its parameters, not 5.
LedControl(int dataPin, int clkPin, int csPin, int numDevices=1);
Where did the suggestion to add a fifth parameter come from ?
UKHeliBob:
but which file did you look into ? because i looked and found it has a fifth boolean
i removed the original LedControl.h and .cpp files and i put instead the LedControlCA.h and .cpp and of course i named them LedControl.h and .cpp
so i get now this error :
so what might be the problem now ?
my sketch file is located on the desktop not inside the arduino reference on D:/
SOLUTION IS:
after downloading the LedControl files of LordPants from github, you must delete the files present name : LedControl.h and LedControl.cpp
then you have to rename LedControlCA.h and LedControlCA.cpp to LedControl.h and LedControl.cpp
then you have to go to the new LedControl.h and add this line with the includes :
#include <common-anode.patch>
and that’s it everything will be fine :slight_smile:
I looked in LedControl.h because that is the file that caused the error.
UKHeliBob:
yea ok i found the solution it's in the reply #4 :slight_smile:
