max7219 RTC 7-segment clock
I got this piece of code of the internet that runs 8 7-segment displays to show the time it also uses a ds1307 RTC so the time is kept when it is switched off but it gets some error messages when I verify it the main one is it says “call of overloaded ‘write(int)’ is ambiguous” what does it mean
// Simple clock using DS1307 RTC chip, Arduino and
// MAX7219 LED display driver
// more information at http://wp.me/pQmjR-BK
#include "Wire.h"
#define DS1307_I2C_ADDRESS 0x68
#include "LedControl.h" //  need the library
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
float t=0;
int a,b;
LedControl lc=LedControl(12,11,10,1); // lc is our object
// pin 12 is connected to the MAX7219 pin 1
// pin 11 is connected to the CLK pin 13
// pin 10 is connected to LOAD pin 12
// 1 as we are only using 1 MAX7219
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
  return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
  return ( (val/16*10) + (val%16) );
// 1) Sets the date and time on the ds1307
// 2) Starts the clock
// 3) Sets hour mode to 24 hour clock
// Assumes you're passing in valid numbers
void setDateDs1307(byte second,        // 0-59
byte minute,        // 0-59
byte hour,          // 1-23
byte dayOfWeek,     // 1-7
byte dayOfMonth,    // 1-28/29/30/31
byte month,         // 1-12
byte year)          // 0-99
  Wire.beginTransmission(DS1307_I2C_ADDRESS);
  Wire.write(0);
  Wire.write(decToBcd(second));    // 0 to bit 7 starts the clock
  Wire.write(decToBcd(minute));
  Wire.write(decToBcd(hour));
  Wire.write(decToBcd(dayOfWeek));
  Wire.write(decToBcd(dayOfMonth));
  Wire.write(decToBcd(month));
  Wire.write(decToBcd(year));
  Wire.write(0x10); // sends 0x10 (hex) 00010000 (binary) to control register - turns on square wave
  Wire.endTransmission();
// Gets the date and time from the ds1307
void getDateDs1307(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
  // Reset the register pointer
  Wire.write(0);
  Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
  // A few of these need masks because certain bits are control bits
  *second     = bcdToDec(Wire.read() & 0x7f);
  *minute     = bcdToDec(Wire.read());
  *hour       = bcdToDec(Wire.read() & 0x3f);  // Need to change this if 12 hour am/pm
  *dayOfWeek  = bcdToDec(Wire.read());
  *dayOfMonth = bcdToDec(Wire.read());
  *month      = bcdToDec(Wire.read());
  *year       = bcdToDec(Wire.read());
  // the zero refers to the MAX7219 number, it is zero for 1 chip
  lc.shutdown(0,false);// turn off power saving, enables display
  lc.setIntensity(0,8);// sets brightness (0~15 possible values)
  lc.clearDisplay(0);// clear screen
  Wire.begin();
  // Change these values to what you want to set your clock to.
  // You probably only want to set your clock once and then remove
  // the setDateDs1307 call.
  second = 0;
  minute = 56;
  hour = 9;
  dayOfWeek = 5;
  dayOfMonth = 9;
  month = 7;
  year = 10;
  //   setDateDs1307(second, minute, hour, dayOfWeek, dayOfMonth, month, year);
    lc.setChar(0,2,'-',false);
    lc.setChar(0,5,'-',false);
    getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);
    if (hour<10)
       lc.setDigit(0,0,0,false);
       lc.setDigit(0,1,hour,false);
    } else if (hour>=10)
      t=hour/10;
      a=int(t);
       lc.setDigit(0,0,a,false);
       t=hour%10;
       lc.setDigit(0,1,t,false);
     if (minute<10)
       lc.setDigit(0,3,0,false);
       lc.setDigit(0,4,minute,false);
    } else if (minute>=10)
      t=minute/10;
      a=int(t);
       lc.setDigit(0,3,a,false);
       t=minute%10;
       lc.setDigit(0,4,t,false);
       if (second<10)
       lc.setDigit(0,6,0,false);
       lc.setDigit(0,7,second,false);
        } else if (second>=10)
      t=second/10;
      a=int(t);
       lc.setDigit(0,6,a,false);
       t=second%10;
       lc.setDigit(0,7,t,false);
when I verify it the main one is it says "call of overloaded 'write(int)' is ambiguous" what does it mean
It says something vaguely like that, but with a lot more detail - like exactly which file and exactly which line. Those details are important.
This is an awful bug in 1.0 to say the least
Where you have
Wire.write(0);
replace it with
Wire.write(zero);
then at the top of your code, under int a,b
byte zero = 0x00;
and you are good to go ;)
