I tested this tut during 3 h.
http://www.arduino.cc/playground/Main/MAX72XXHardware
I used this code:
http://www.arduino.cc/playground/LEDMatrix/Max7219
of course I modified this code with:
- the right number of max7219,
- the right Dout pins of my Wiring board.
it should work, it doesn’t…! :’(
any experiencies ? ideas ?
my code:
I put the Serial stuff at the end in order to watch the loop running.
int dataIn = 5;
int load = 6;
int clock = 7;
int maxInUse = 1; //change this variable to set how many MAX7219’s you’ll use
int e = 0; // just a varialble
// define max7219 registers
byte max7219_reg_noop = 0x00;
byte max7219_reg_digit0 = 0x01;
byte max7219_reg_digit1 = 0x02;
byte max7219_reg_digit2 = 0x03;
byte max7219_reg_digit3 = 0x04;
byte max7219_reg_digit4 = 0x05;
byte max7219_reg_digit5 = 0x06;
byte max7219_reg_digit6 = 0x07;
byte max7219_reg_digit7 = 0x08;
byte max7219_reg_decodeMode = 0x09;
byte max7219_reg_intensity = 0x0a;
byte max7219_reg_scanLimit = 0x0b;
byte max7219_reg_shutdown = 0x0c;
byte max7219_reg_displayTest = 0x0f;
void putByte(byte data) {
byte i = 8;
byte mask;
while(i > 0) {
mask = 0x01 << (i - 1); // get bitmask
digitalWrite( clock, LOW); // tick
if (data & mask){ // choose bit
digitalWrite(dataIn, HIGH);// send 1
}else{
digitalWrite(dataIn, LOW); // send 0
digitalWrite(clock, HIGH); // tock
–i; // move to lesser bit
void maxSingle( byte reg, byte col) {
//maxSingle is the “easy” function to use for a //single max7219
digitalWrite(load, LOW); // begin
putByte(reg); // specify register
putByte(col);//((data & 0x01) * 256) + data >> 1); // put data
digitalWrite(load, LOW); // and load da shit
digitalWrite(load,HIGH);
void maxAll (byte reg, byte col) { // initialize all MAX7219’s in the system
int c = 0;
for ( c =1; c<= maxInUse; c++) {
void maxOne(byte maxNr, byte reg, byte col) {
//maxOne is for adressing different MAX7219’s,
//whilele having a couple of them cascaded
int c = 0;
for ( c = maxInUse; c > maxNr; c–) {
putByte(0); // means no operation
for ( c =maxNr-1; c >= 1; c–) {
void setup () {
pinMode(dataIn, OUTPUT);
pinMode(clock, OUTPUT);
pinMode(load, OUTPUT);
//initiation of the max 7219
maxAll(max7219_reg_scanLimit, 0x07);
maxAll(max7219_reg_decodeMode, 0x00); // using an led matrix (not digits)
maxAll(max7219_reg_shutdown, 0x01); // not in shutdown mode
maxAll(max7219_reg_displayTest, 0x00); // no display test
for (e=1; e<=8; e++) { // empty registers, turn all LEDs off
maxAll(e,0);
maxAll(max7219_reg_intensity, 0x0f & 0x0f); // the first 0x0f is the value you can set
// range: 0x00 to 0x0f
void loop () {
Serial.println(“okk”);
maxSingle(1,4);
maxSingle(2,2);
delay(2000);
maxSingle(1,0);
maxSingle(2,0);
