MAX7219 with 7segments error in for() loop ! help !
hello guys,
i manage to make the MAX7219 work with Common Anode double digit 7-segment, i am using this library
https://github.com/deruiter/DCF77-Analyzer-Clock/tree/master/LedControl%20added%20COMMON%20ANODE%20display%20support
what is happening is that i am making a count up from 0 to 9999, so the count is stopping at 0001 and doesn’t go up, so i removed the for() loop and tested it without it to see if it can print any number i give to the variable i and it worked totally fine but when i add the for() loop it’s stopping at the 0001
this happened to me when i used a CC display and programed it but i found the solution but this solution is not working here so can anyone help please ?
here are the codes :
//We always have to include the library
#include <LedControl.h>
 Now we need a LedControl to work with.
 ***** These pin numbers will probably not work with your hardware *****
 pin 12 is connected to the DataIn
 pin 11 is connected to the CLK
 pin 10 is connected to LOAD
 We have only a single MAX72XX.
LedControl lc=LedControl(12,11,10,1,true); //true for Common Anode
   The MAX72XX is in power-saving mode on startup,
   we have to do a wakeup call
  lc.shutdown(0,false);
  /* Set the brightness to a medium values */
  lc.setIntensity(0,15);
  /* and clear the display */
  lc.clearDisplay(0);
 This method will display the characters for the
 word "Arduino" one after the other on digit 0.
void displayCount(){
  int i;
  int ones;
  int tens;
  int hundreds;
  int thousands;
  for(i=0; i<10000; i++){
    ones=i%10;
    i=i/10;
    tens=i%10;
    i=i/10;
    hundreds=i%10;
    i=i/10;
    thousands = i;
    lc.setDigit(0, 0, ones, false);
    lc.setDigit(0, 1, tens, false);
    lc.setDigit(0, 2, hundreds, false);
    lc.setDigit(0, 3, thousands, false);
    delay(100);
  displayCount();
What is the value of i at the end of your for loop?
You are changing the loop index in the loop, you should make a copy of the index and change that.
Whandall: What is the value of i at the end of your for loop?
it is the value that it started with in the for loop between 0 and 10000
Whandall: You are changing the loop index in the loop, you should make a copy of the index and change that.
what do you ?
the same example worked for 2 digits but not with 4 :/ why ?!
do you mean i must take the i and put it at the top of the file sketch ?
firashelou: it is the value that it started with in the for loop between 0 and 10000 what do you ?
That's not true.
i contains the tenthousands of the index, which will stay zero.
Whandall:
That’s not true.
what do you mean ?
example which i wrote on my notebook :
i = 1521
ones = i%10 = 1
i=i/10 = 152
tens = i%10=2
i=i/10=15
hundreds = i%10=5
i=i/10=1
thousands = i = 1
check this it works totally fine for 2 digits :
LedControl lc=LedControl(12,11,10,1);
  lc.clearDisplay(0);
  int i;
  int ones;
  int tens;
  for(i=0; i<100; i++){
    ones=i%10;
    tens = i/10;
    delay(100);
  displayCount();
In the code for the two digits you do not change i inside the loop, you act on copies, as I suggested to do.
And if you don't know how to/understand
'make a copy of an int and use that',
I'm very sorry, but I will not write your code, even though writing the denial consumes more time and keystrokes.
In your first version you have
    i=i/10;
    i=i/10;
    i=i/10;
that changes the value of i, doesn't it?
Whandall: In your first version you have
    i=i/10;
    i=i/10;
    i=i/10;
yes of course it changes to the new value let's say it shrinks ^_^
i am using the method in this example from the section of controlling the 7-segment http://playground.arduino.cc/Main/LedControl
but why when i wrote it on paper it is right ?
can you give me a hint please ? because i made this post after many tries and frustrations which kept me no choice :/
you telling me to make a new int variable let's say int a and use it to store the new values ?
I would suggest using something like
int number = i;
    number = number / 10;
or shorter
int number = i;
    number /= 10;
    number /= 10;
    number /= 10;
and using number for the output of the digits.
Whandall:
int number = i;
or shorter
int number = i;
number /= 10;
    number /= 10;
    number /= 10;
yes exactly as i thought not mess with the i because it’s for the for loop it worked fine thanks a lot :smiley:
