max7219
Hello
I have a question I have a max7219 display
and I have for example its on
Write_Max7219 (1, 00011000);
I would like to add a 1 on each side in a loop in the fure and a measure
Write_Max7219 (1, 00111100);
and after adding 1 on the column below from the first
and that its approval as its forth
Write_Max7219 (1, 01111110);
Write_Max7219 (2, 00111100);
Write_Max7219 (3, 00011000);
thank you in advance
Have you attempted to write anything or any numbers to this display even just to test it ?
If so, post some working code so it is clear what libraries etc. you are using.
I hope you have figured out that “00111100” is not the same as “0b00111100”
In the immortal words of Pete Hogwallop, “That don’t make no sense!”
sorry, I was wrong my code
Write_Max7219(1, B00011000);
6v6gt:
yes everything else works
the display and that's what I put on it
and I don’t use libraries
I didn't understand what it really does and how it works
so it gives
Write_Max7219 (1, B00011000);
delay(X)
Write_Max7219 (1, B00111100);
Write_Max7219 (2, B00011000);
delay(X)
Write_Max7219 (1, B01111110);
Write_Max7219 (2, B00111100);
Write_Max7219 (3, B00011000);
delay(X)
Write_Max7219 (1, B11111111);
Write_Max7219 (2, B01111110);
Write_Max7219 (3, B00111100);
Write_Max7219 (4, B00011000);
delay(X)
Write_Max7219 (2, B11111111);
Write_Max7219 (3, B01111110);
Write_Max7219 (4, B00111100);
delay(X)
in less line
and in a for
ludocraft:
Where is this function Write_Max7219(a,b) defined if you are not using any libraries ?
If you have not yet got any code to write (just anything) to the max7219, find an example and play with that first before starting to attempt to display a string representation of a binary number.
Post the entire sketch, not just a snippet of it.
6v6gt:
//configuration pin
#define Max7219_pinCLK	10
#define Max7219_pinCS	11
#define Max7219_pinDIN 	12
//annimation
#define chargement	0
#define normal		1
#define droite		2
#define gauche		3
#define cligne		4
#define mort		5
#define revie		6
#define amoure		7
//variable
unsigned char choix  =4;
unsigned char select =0;
char f =0;
char m =1;
//fonction
void Init_MAX7219();
void Write_Max7219(unsigned char address, unsigned char dat);
void Write_Max7219_byte(unsigned char DATA);
	pinMode(Max7219_pinCLK, OUTPUT);
	pinMode(Max7219_pinCS, OUTPUT);
	pinMode(Max7219_pinDIN, OUTPUT);
  delay(60);
	Init_MAX7219();
  delay(50);
	switch (choix){
		case 1 :{//normal
			Write_Max7219(1, 126) ;
			Write_Max7219(8, 126) ;
				for (int f =2; f <7; f++){
				Write_Max7219(f, 66);
		delay(5);
			for (int f =3; f <7; f++){
			Write_Max7219(f, 90);
		f=0;
		delay(50);
		break ;
		case 2 :{//droite
			for (f =3; f <7; f++){
				Write_Max7219(f, 78);
			Write_Max7219(1, 63);
			Write_Max7219(8, 63);
			Write_Max7219(2, 33);
			Write_Max7219(7, 33);
					Write_Max7219(f, 39);
				Write_Max7219(f, 45);
				Write_Max7219(f, 57);
			choix=1;
		break ;}
		case 3 :{//gauche
				Write_Max7219(f, 114);
			Write_Max7219(1, 252);
			Write_Max7219(8, 252);
			Write_Max7219(2, 132);
			Write_Max7219(7, 132);
					Write_Max7219(f, 228);
				Write_Max7219(f, 180);
				Write_Max7219(f, 156);
			choix=1;
		break ;}
		case 4 :{//cligne
			if (f ==0){
				for (f =1; f <8; f++){
					Write_Max7219(f, 126);
				delay(150);
			Write_Max7219(7, 66);
				for (f =6; f >2; f--){
				delay(150);
			 choix =1;
		break ;}
		case 5 :{//mort
			if(select < 200){
				for (f = 1; f <= 8; f++ ){
					int bit1 = 1 << (rand() & 7);
					int bit2 = 1 << (rand() & 7);
					int bit3 = 1 << (rand() & 7);
					int bit4 = 1 << (rand() & 7);
					Write_Max7219(f, bit1 ^ bit2 ^ bit3 ^ bit4 );
					select++;
				delay(75);
			else{
				delay(random(1000, 2000));
				Write_Max7219(4, B00011000);
				delay(100);
				Write_Max7219(3, B00011000);
				Write_Max7219(4, B00111100);
				Write_Max7219(5, B00011000);
				delay(100);
				Write_Max7219(2, B00011000);
				Write_Max7219(3, B00111100);
				Write_Max7219(4, B01111110);
				Write_Max7219(5, B00111100);
				Write_Max7219(6, B00011000);
				delay(100);
				Write_Max7219(2, B00111100);
				Write_Max7219(3, B01111110);
				Write_Max7219(4, B11111111);
				Write_Max7219(5, B01111110);
				Write_Max7219(6, B00111100);
				Write_Max7219(7, B00011000);
				delay(100);
				Write_Max7219(1, B00100100);
				Write_Max7219(2, B01111110);
				Write_Max7219(3, B11111111);
				Write_Max7219(6, B01111110);
				Write_Max7219(7, B00111100);
				Write_Max7219(8, B00011000);
				delay(100);
				Write_Max7219(1, B01100110);
				Write_Max7219(2, B11111111);
				delay(100);
					choix=1;
		break ;}
void Init_MAX7219(void)
  Write_Max7219(0x09, 0x00);       //decoding :BCD
  Write_Max7219(0x0a, 0x03);       //brightness
  Write_Max7219(0x0b, 0x07);       //scanlimit;8 LEDs
  Write_Max7219(0x0c, 0x01);       //power-down mode:0,normal mode:1
  Write_Max7219(0x0f, 0x00);       //test display:1;EOT,display:0
//Ecriture sur une rangee
  digitalWrite(Max7219_pinCS, LOW);
  Write_Max7219_byte(address);           //address,code of LED
  Write_Max7219_byte(dat);               //data,figure on LED
  digitalWrite(Max7219_pinCS, HIGH);
// Ecriture sur un 8x8
  unsigned char i;
  for (i = 8; i >= 1; i--)
    digitalWrite(Max7219_pinCLK, LOW);
    digitalWrite(Max7219_pinDIN, DATA & 0x80); // Extracting a bit data
    DATA = DATA << 1;
    digitalWrite(Max7219_pinCLK, HIGH);
case after if in the game else if
Wuh?
TheMemberFormerlyKnownAsAWOL:
Wuh?
sorry my me and english its done 2 i help me google translation
OK. So it appears you have a single 8x8 led matrix module.
Something like this ?
6v6gt:
yes its just the chip and under the leds
OK. It looks we have some code from you and some idea of the display device.
It appears that you want to add a new choice (choix) with a value of, for example, 6 which displays a new pattern
.XXXXXX.
..XXXX..
...XX...
Perhaps this pattern is static, or perhaps it moves up, down, left right etc. and with some timing intervals.
Is that correct ?
6v6gt:
.XXXXXX.
..XXXX..
...XX...
Is that correct ?
dans le temp sa fait sa
...XX...
delay
..XXXX..
...XX...
delay
.XXXXXX.
..XXXX..
...XX...
delay
XXXXXXXX
.XXXXXX.
..XXXX..
...XX...
delay
XXXXXXXX
XXXXXXXX
.XXXXXX.
..XXXX..
...XX...
delay
XXXXXXXX
XXXXXXXX
XXXXXXXX
.XXXXXX.
..XXXX..
...XX...
(X=1 and .=0)
in the meantime i found the answer on another server thanks for your help
const byte lesOctets[] = {
  0b00011000,
  0b00111100,
  0b01111110,
  0b11111111,
  0b11111111
const byte total = sizeof(lesOctets) / sizeof(lesOctets[0]);
void imprimeOctet(byte unOctet)
  for (char i = 7; i>=0; i--)
  Serial.write(bitRead(unOctet, i) == 0 ? '-' : 'X');
  for (uint8_t i = 0; i < total; i++) {
    for (uint8_t j = 0; j <= i; j++) {
      Serial.print(j + 1);
      Serial.write('\t');
      imprimeOctet(lesOctets[i-j]);
    Serial.println(F("delay(X)\n"));
void loop() {}
