MAX72xx RGB
im considering the MAX72xx to control my 16x6 RGB backlight for my keyboard
will 6 MAX7219 work?
if so, how do i make it work?
if not, what will do the trick?
thanks in advance
You could make it work, using 3 for each 8x6 block, You'd have to do your own time multiplexing between colors, putting 2 in shutdown while the 3rd was active, and adding diodes to isolate the active part from the inactive parts.
Pretty sure there are better options.
thanks for the reply!
although i dont understand 50% of it :stuck_out_tongue:
i will research more and post it here if i find anything
Shutdown Mode
When the MAX7219 is in shutdown mode, the scan oscillator
is halted, all segment current sources are pulled to
ground, and all digit drivers are pulled to V+, thereby
blanking the display. The MAX7221 is identical, except
the drivers are high-impedance.
So with MAX7219, you need diodes between segment (anode) drivers, and diodes between the digit (cathode) drivers. Then the part that is shutdown is not pulling the anodes of the active device low, and does not drive the cathodes high.
MAX7221 is better, the outputs are just turned off, and do not interfere with the other devices.
I'd draw a picture, but it's late and I'm tired.
woah....
thanks for the detailed explanation!
your willingness to help people is mind blowing
thanks again!
Look at the TLC5940 instead.
// Per.
Or ws2812b leds.
With max7219 you will get a choice of 6 colours. With ws2812B you can mix many colours and shades, and wire them in one long chain back to a single Arduino pin. No extra chips, because each led has its own built-in driver chip.
Actually, a MAX7219 can control basic RGB LEDs quite well - with the constraint that you do not have individual intensity control. For keyboard lighting, this will be no concern as you only want basic colours.
Now unless you use six-wire RGB LEDs - that is, with both connections separate for each colour - you can only use two LEDs per row or column as you are using 6 of the 8 lines for the colours and the other two cannot partly power the RGB LED, so the MAX7219 can control just 16 RGB LEDs. So it seems that six of them would be fine for your 6 x 16 array, each MAX7219 controlling an entirely separate array of 16 LEDs.
PaulRB:
Or ws2812b leds.
that would actually be perfect!
i will research about it
thanks!
Paul__B:
does the MAX7219 use PWM to control the colors?
if so, how do i use the PWM?
The MAX7219 uses PWM to control overall brightness. Thus I said:
Paul__B:
Red, yellow, green, cyan, blue, magenta.
