Max7456 osd setup
Hello,
I'm after a detailed tutorial of the setup and use of arduino with a max7456 osd
What have you tried ?
Are you willing to pay for someone to write this for you ?
Wrote nothing yet, just finding the resources first.
I can't I'm a student don't have the funding to pay.
What exactly do you want/need to do with the max7456 osd ?
A quick search found this http://www.hobbytronics.co.uk/max7456-osd-breakout
Thanks, UKHeliBob,
I am doing a project and would like some information sent back to the fpv goggles that I have, I currently have an Arduino nano controlling two servos and connected to an nrf24 module, will adding the code to send data to osd cause a problem? with the current configuration.
I have one of these that's spare from a drone, Minim OSD Quick Installation Guide — Copter documentation
I believe it the same as the one you linked too just different size.
I currently wish to send battery voltage back, temp and expand on this at a later date.
So I've had a chance to get some research in, now the OSD I have is based on an arduino pro mini with a max7456 chip too, can I have my nano communicate the required date from the nano to the pro mini base OSD over TTL, then flash the OSD with the required script to place that data using the Avamander /
max7456
