Max7456
Hi guys have no clue what I am doing
but what I can tell you is what I need
I've search long and hard but cannot
Understand how I'm supposed to
Add my own text shape to spark fun max7456
Osd what I need may sound simple to you
But for someone with no programming skills
What so ever it's a hard climb so asking for some
Guildence I need to overlay a crosshair over a CCTV
Video at full screen Can it be done is there a simple
Programme that can do all the magic I've tried maxim evaluation
Kit I've made a nice cross hair but what do I need to do
To get said cross hair onto arduino then onto the spark fun max7456
Thanks any input would greatly welcomed
I'm not sure what you are asking for...
Are you having a problem with the MAX7456?
Are you looking for help to connect an Arduino to the MAX7456?
Are you looking for help writing code to communicate with the MAX7456?
If you really have no programming experience, then I suggest going through some tutorials on programming and Arduino first. You will need to control pins and communicate over SPI. You will probably want to communicate over serial because you can't see what's going on when the code is running in and Arduino, so it is helpful to put print statements in the code at various points and watch using the serial monitor, so you can track the logic of the code and see internal variables.
What i Wanted to do was
this
http://www.micrio.com/images/file/XH300AS_Crosshair_Generator_Rel_1_6.pdf
but with the arduino and max7456 but i cant get my head around what programe languge i should use
so am thinking of buyin the XH300AS
