Hello,
I have been fighting with Maxbotix EZ1 sensor for a while. It seems I'm not getting sensible values from the ultrasonic sensor.
In case I connect sensor's "PW pin" to arduino's digital pin and divide the reading value by 147 (147uS per inch) and multiply by 2.54 (1 inch = 2.54 cm) I get values between 150cm-50cm. The first strange thing is that I get lower reading when I move my hand out of the sensor. The second strange thing is that I actually get reading from 0-5 cm away from the sensor. It doesn't detect anything away 5 cm. According to the specs (maxbotix.com/uploads/LV-MaxSonar-EZ1-Datasheet.pdf) "Objects from 0-
inches to 6-inches range as 6-inches" so it shouldn't even be detecting as close range values as I can get. Eventhough I can get very precise readings from 0-5 cm away from the sensor, that's not really what I'm after. The output values are also very inaccurate (150cm-50cm).
It is also possible to connect sensor's "AN pin" to arduino's analog pin. This seems to be a way more popular method, but I get constantly floating values (values up to ~600). Voltage seems to be changing every moment even if I keep my hand at fixed height above the sensor.
I think it would be a good idea to also post the code I'm using with my arduino board.
//This code is for the digital pin mode
int pingPin = 7;
int ledPin = 13;
pinMode(ledPin, OUTPUT);
long duration, cm;
long inches;
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
// convert the time into a distance
//inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
//Serial.print(inches);
//Serial.print("in, ");
Serial.print(cm);
Serial.print("cm");
delay(10);
long microsecondsToInches(long microseconds)
return microseconds / 147;
long microsecondsToCentimeters(long microseconds)
long inches = microseconds / 147;
return inches * 2.54 ;
//end of digital pin mode
And code for analog pin mode:
//Analog mode
//Output
int statusLed = 13;
//intput
int analogSignal = 0;
pinMode(statusLed,OUTPUT);
pinMode(analogSignal,INPUT);
int val = analogRead(analogSignal);
if (val > 0) {
// The Maxbotix reports 512 steps of information on AN
// but we read that as 1024. Each step is 1", so we need
// to divide by 2 to get the correct rough range in inches.
// this value should also be calibrated for your particular
// sensor and enclosure
val = val / 2;
val = val * 2.54;
Serial.println(val); // cm
blinkLed(statusLed,100);
void blinkLed(int pin, int ms) {
digitalWrite(pin,LOW); // turn it off it was on
digitalWrite(pin,HIGH);
delay(ms);
delay(ms);
//end of analog mode
If someone has arduino and maxbotix sensor, could you please provide some help and probably the code that works for you. I would also like to know if it's better to use digital or analog mode. At the moment I'm declining to a digital mode.
