I'm a little confused about baud rate in general. Does it only affect serial communication? I'm using two Maxbotix LV EZ 1's set at 9600 bps. According to what I have read, when i interface my bluetooth (bluetooth mate), it will require 57600 bps. I'm manually using the RX pin as a trigger to turn on and off the PWM pin of the sensor. My question is: Will changing the baud rate affect the delays needed for the sensors to read. For example...Does 50 milliseconds at 9600 bps = 50 milliseconds at 57600 bps within the code? Here's a snippet of the code for one of the sensors:
for(int i = 0; i < arraysizeR; i++)
digitalWrite(TriggerR, HIGH);
delayMicroseconds(200);
digitalWrite(TriggerR, LOW);
pulseR = pulseIn(SonarR, HIGH);
rangevalueR[i] = pulseR/147;
delay(50);
No, as serial communication takes time it can completely corrupt your sketch in theory as communication overhead can cost too much time. So you better use 115200 iso 1200 baud. You can even go higher (230400,345600) with the Arduino but the IDE serial monitor can only handle up to 115200.
50 millis == 50 millis
But the microdelay between two pulses at different baudrates differ substantially:
9600 baud => 1.000.000 micros / 9600 = 104.16 micros
57600 baud => 1.000.000 micros / 57600 = 17.36 micros
does a delay of 1 second in my sketch at 9600 bps equal a delay of 1 second in my sketch at 57600 bps? Or at 115200 bps?
delay (1000); //at 9600 bps is this equal or not equal to delay(1000); // at 57600 bps
The baudrate as is will not affect the timing of the delay function in theory. But in practice there can be small differences even at the same baudrate, but these differences will be small.
Do a timing with micros() and print it to see the difference.
uint32_t start = micros();
uint32_t stop = micros();
Serial.println(stop-start);
Serial.begin(57600);
start = micros();
stop = micros();
start = micros();
stop = micros();
mine printed:
1000004
1000008
1000004
QED.
Good News. Thanks very much
