Maximum and minimum voltage for sensor?
Hello everyone
i have an ultrasonic sensor HCSR-04 ,
i read that it operate on 5v for 'vcc' pin put i don't know how much voltage need for the trigger pin !, however , i was working on Arduino UNO using digital pins which it is ~5v if this pins is 'HIGH'.
my question is :
if i want to use PWM pins and apply analogWirte(100) ,does the ultrasonic will operate same if i am using digital pin that goes only HIGH or LOW ? ?
It makes no sense to use PWM to operate an ultrasonic distance sensor.
You might be confused by the term analogWrite(). The output is not an analog signal but a PWM signal. So the voltage will always be 5V (on the UNO), it’s just turned on and off for different periods of time in a fast repetition.
You might be right ,it make no sense but i run into a situation that the I/O pins provide only2.3v?
TheNoneP:
An average voltage (which a multimeter is going to read) of about 2.3V is what you'd expect to see from an analogWrite(100). The pin will be high (5V) a bit less than half the time and low (0V) for the rest.
Steve
So PWM will not modify the voltage value ?
What is the voltage required for trigger pin in ultrasonic?
The data sheet for the devices shows:
"(1) Using IO trigger for at least 10us high level signal,".
High level means 5 volts in this case.
Paul
Which I/O pins? Are you trying to replace another board by an Arduino? What are you trying to achieve?
That depends on the board used, in your case it's 5V as Paul_KD7HB already mentioned.
