warren_spencer_1977:
So… where can I see the linker map to find out where things are landing in memory?
Run avr-size on the .elf file in the sketch library. Here’s what I found from the example that I show below:
From avr-size after compiling with avr-gcc 4.3.4 on my Linux system:
[dave@starrx tmp]$ avr-size build5021398062739215153.tmp/*.elf
text data bss dec hex filename
3296 34 168 3498 daa build5021398062739215153.tmp/sketch_jun28b.cpp.elf
The number in the “text” column tells you how much program memory the sketch is using.
The number in the “data” column is the number of bytes in RAM storage that are initialized upon startup. This number will include the number of bytes in const C-style “strings,” or char arrays that are initialized with C-style “strings,” since the “strings” have to be copied from program memory to RAM in the avr-gcc initialization code so that programs can access them normally.
The number in the “bss” column is the number of bytes in RAM static storage.
The sum of the “data” and “bss” numbers do not give the total RAM usage, since they don’t take stack size, heap size or storage for automatic variables into consideration. But you can see how the “data” number grows if you add “normal” C-style strings to the sketch.
The Arduino PROGMEM Reference page gives some information and examples about how to get constant strings (and other constant stuff) into program memory and save some RAM.
Even better (I think)…
Mikal Hart’s Flash library is, in my opinion, an absolutely marvelous set of classes that not only makes it easier (well, it seems easier to me) to get strings (and other stuff) into (and out of) program memory but implements a streaming operator that allows you to access data from program memory without having to copy it into data RAM. It has ways of creating 1-D data arrays and 2-D data tables, not just strings
A simplified demo of some of the string stuff:
// Mikal Hart's Flash library and streaming operator
// davekw7x
#include <Flash.h>
FLASH_STRING(kirkUniverse, // The name of the "string"
"What is a man but that lofty spirit, that sense of ...\n"
"enterprise? That devotion to something that cannot be\n"
"sensed, cannot be realized, but only ... dreamed!\n"
"\n--- Capt. James T. Kirk\n");
FLASH_STRING(adamsUniverse,
"There is a theory that if anyone ever figures out exactly\n"
"what the universe is for and why it is here, it will instantly\n"
"disappear and be replaced by something even more bizarre and\n"
"{inexplicable.\n\n"
"There is another that this has already happened.\n"
"--- Douglas Adam\n");
Serial << F("This is an example of streaming a string. The string is in program memory, not RAM\n");
Serial << F("Now, here's an example of named string in PROGMEM\n");
Serial << F("The size of the string in PROGMEM is ") << kirkUniverse.length() << " bytes.\n";
Serial << F("The string takes up ") << sizeof(kirkUniverse) << F(" bytes in RAM.\n");
Serial << F("\nHere's the string:\n\n");
Serial << kirkUniverse;
Serial << F("\n\nWanna see another??? OK:\n\n");
Serial << adamsUniverse;
Serial << F("\n\nRegards, Dave\n");
void loop(){}
Output from the program
This is an example of streaming a stream. The string is in program memory, not RAM
The size of the string in PROGMEM is 184 bytes.
The string takes up 4 bytes in RAM.
Here's the string:
inexplicable.
--- Douglas Adam
Regards, Dave
Footnote:
So: You can create strings in program memory and use their names in various ways or you can create instant strings “on the fly” without using space in data RAM.
Keep building more and more strings in program memory (or use more Serial << F(“whatever”
strings in output statements). The RAM requirements do not grow.
Add some “normal” strings, like Serial.println(“whatever”);, and you can see that the “text” (Program Memory) requirements grow as do the “data” (RAM) requirements.
What’s not to like??? Well it’s a new kind of output statement for some Arduino programmers (not harder, I think, just different), but for C++ guys, it’s like a breath of fresh air, right? I mean, the library functions take some space (nothing is free, right)? But the simplicity and convenience of the Flash library notation just gasts my flabber.
Keep paying attention, folks, it’s my understanding that things like the “streaming strings” stuff are coming in an official Arduino release, “real soon, now.”
