From playing with it, it looks like the argument to the delay() function is treated as a signed int, making the maximum delay something like 32767 milliseconds. Is that correct? If so, it would be helpful to update the reference page for delay() to make this clear. Currently there's no mention there of a maximum possible delay.
I noticed this when I tried setting a delay of 60*1000 (one minute) and found that my sketch just hung at that point. A delay of 30000 works, on the other hand.
My bad. I see now (from wiring.h) that the delay() function takes an unsigned long, so it should work for much longer delays than I was trying to use. My mistake was multiplying a signed integer variable and a signed integer constant to get the delay time. Making the variable unsigned long fixed things.
I'm puzzled why the 60 * 1000 didn't work but passed (I presume?) the compiler's validity tests, and would welcome claification on that point.
And even though it wasn't the answer to what you were seeing, I'd welcome what you suggested. If someone who knows the answer would modify the entry at....
... to make explicit what the largest acceptable arguement is, I think it would be a good addition. The entries for miilis and pulseIn are very good in this respect. It would be great if the explicit statement of different functions needs were to be extended.
I just did a few quick tests, and I think the issue is not with the delay() function, but with the multiplication. The compiler treats an "integer literal" (e.g. 60 or 1000) as an "int" (which can hold numbers from -32,768 to 32,767) not as a long (which goes from negative to positive 2 billion or so). So when you try to multiply the two integers 60 and 1000, the result (60,000) is bigger than what can fit in an int, and so it overflows to a negative number. Then delay() gets called with a negative number (which actually gets turned into a very large positive one, since delay() takes an unsigned long), which makes it hang. You can get around this by putting an L after one or both of the numbers, e.g. delay(60L * 1000L); (as described, though not in much detail on the integer constants page).
I'll add something about not passing a negative number to delay(), and try to clarify what happens when arithmetic overflows on the arithmetic page. And also the fact that numbers like 60 are treated as integers (not longs).
Could some C++ strong typing, function overloading, and an extra version or three of delay() take care of this problem? Maybe one delay() for each of the following input types: int, unsigned int, long, unsigned long.
Of course, there's not a lot of room on the ATmega for code bloat...
As David explained, the problem is fundamentally that 60*1000 does not equal 60,000 here, because the result is an int (a signed 16 bit integer). There's no way to catch that at the compiler level (that I can think of, anyway); you need to promote one or both of the constants to a long (32 bit integer) to get a result of 60000.
The best you could do (I think) would be have a version of delay that accepted an int, and which would barf when given a negative delay.
I do want to look through the gcc documentation, though, because it's smart enough to treat 60000 (for example) as a long, even without an L at the end. Maybe there's an option to tell it to treat all integer literals as longs (or something similar).
Casting should work as does appending L to the integer literals (e.g. 60L). But, of course, that only helps if you know you need to do it. I'm not sure of the best way to help people that don't know they need to do that.
If the arduino distribution had delay declared as a macro (with the actual function renamed to _delay) then this would do the cast without the user knowing anything about it. It would look exactly the same as now but would operate as a long.
Again, the problem is with the arithmetic, not with the delay() function. When you multiply the 16-bit signed integers 60 and 1000, you don't get 60000, but rather -5536. (The biggest number you can represent as a 16-bit signed integer is 32767.) Casting that result to an unsigned long doesn't get you 60000 back. You need to do something to make sure the arithmetic is carried out using unsigned longs (32-bit integers) in the first place. It's not clear there's any convenient way to do that automatically, however.
A way of helping people avoid this mistake in the first place might be to provide special delay_() functions for longer time units, and then document clearly what the maximum argument for each is. If there were a delay_minutes() or delay_seconds() function, for instance, you wouldn't need to multiply 601000 to get the delay. These special variants could easily be implemented as macros, e.g.,
Casting the parameter in a macro to an unsigned long forces the compiler to do the entire calculation as a long in other platforms I have used. Are you saying that the suggestion to use a macro with the cast wont work here?
It might or it might not, depending on how the function is called. In particular, it won't work unless the arithmetic is being done right there in the function call. So, it would allow "delay(60*1000)" to work, but not, for instance, "int interval = 60 * 1000; delay(interval)".
Tom, your comment is an example of how the compiler can generally overflow integer math, I don't think there is any way to reduce the general problem you show in your example other than educating users on the nature of type overflow.
I thought the subject of this thread was how to address overflow in the argument to the arduino delay function.
It seems to me that we help users with overflows in the arguments of functions like delay if the cast is implicitly done by calling the function through a macro. I wonder if you think that would be worthwhile.
My main request when I started the thread to have the documentation improved, to explain more clearly how to use the delay() function correctly. The docs still don't indicate what the type of the argument is. A warning there about the perils of 16-bit arithmetic would also be pretty helpful.
I agree it would probably help most people avoid the mistake I made, and to that extent it might be worthwhile. On the other hand, it doesn't help people understand what they're doing.
My main objection to the macro, however, is that the way it works is a bit unclean. The cast doesn't act on the argument as a whole, but depends on it being an arithmetic expression that can be modified before it's evaluated. Usually, you try to avoid writing macros that work that way because they lead to code that fails mysteriously. In this case, for example, the following cases do and don't work...
So, the simplest and most common usages of the function would now work, but the reason why the last two examples fail would be hard to explain. Just as C code, all four of my examples would ordinarily be expected to produce the same result, since all four delay() arguments evaluate to the same value when taken by themselves. Of course, without the macro, all four examples would fail, but once you understood why, you'd have learned something useful and (hopefully) become a better C programmer.
Actually the fourth example of the macro does exactly what you expect it to do (garbage in/garbage out). And I do think an inexperienced programmer is much more likely to use the second case rather than the third.
I do wholeheartedly agree that documentation and education are the best prevention for this problem. But it has been my experience that many that are attracted to the arduino enthusiastically jump in the deep end with some playground code that is related to their needs and don't spend a lot of time reading about syntax or semantics
Anyway, the decision for the arduino team is to decide if they want to provide a little bit of a safety net here or not.
I imagine that those that read this thread are unlikly to easily fall into the trap so thanks for raising the issue
